Author Topic: Donkey Kong Monitor Issues  (Read 16991 times)
calz
  • Last login:December 19, 2017, 12:24:42 am
« on: November 02, 2011, 11:31:26 am »
Hi All -
Picked up a DK and seeing some issues with the monitor. Anyone seen this before? Wondering if I need a new monitor or cap kit?
Thanks,
Chris
lilshawn
Re: Donkey Kong Monitor Issues
« Reply #1 on: November 03, 2011, 03:31:20 pm »
is that ONLY what it displays? or does it show that over top of the game video?
calz
« Reply #2 on: November 03, 2011, 04:02:02 pm »
I  can barley see the game moving under this screen... can hear sounds and game seems to runs fine. Only see very light ghosts underneath this screen.
mgb
  • North East, US
« Reply #3 on: November 03, 2011, 11:03:19 pm »
....Only see very light ghosts underneath this screen.
Theres your problem, you're seeing pacman, there are no ghosts in Donkey Kong.... Just Kidding.
A cap kit should most likely be done. also check and adjust the b+ voltage (should be 108vdc).
You can get the Sanyo 20ez deluxe kit from Bob Roberts, it also includes the caps and transistors needed for the sound board.
calz
« Reply #4 on: November 04, 2011, 12:12:13 am »
haha... cool thanks. I've never done this before but will order and give a shot (and not sure how to adjust the b+ voltage). Will report status back here as well. Thanks for the help!
mgb
  • North East, US
« Reply #5 on: November 04, 2011, 10:11:01 am »
Cap kits are relatively easy, you just need to know some basic things.
There is a lot of good information on the web.
Do research and you'll be fine.
There is a pin to meter your b+ voltage at and there is a pot for adjustin it below. Just beware that the pot used for adjusting B+ is set with a little glue and that pot is fragile and easily broken. When you get the cap kit, you may also wanna order a sanyo 20ez b+ pot (also from Bob Roberts) its a 5k pot.
calz
« Reply #6 on: November 05, 2011, 12:15:09 pm »
Cool. Did some research and does not look that bad... only scary thing is the discharge. Ordered the parts and we'll see how it goes :-). One fear that I have is not knowing if there is screen burn-in based on the current picture, and if I fix will be time wasted. I think this machine came from a bowling alley and my goal is to restore it to tip top shape for the collection. Thanks again for the help!
mgb
  • North East, US
« Reply #7 on: November 06, 2011, 12:58:40 am »
alot of guys woory about the first discharge, but don't worry. Its hardly as bad as some think it will be.
calz
« Reply #8 on: December 03, 2011, 11:52:41 pm »
OK, so I have the cap kit now, built the screwdriver tool for discharge, and attempted to do this tonight. When I touch the screwdriver to the piece under the anode I did not hear a pop or see sparks or anything... have not turned the game on in a few weeks, so wondering if it discharged itself? How can I know for sure that I am not going to get zapped pulling the anode off  :)
mgb
  • North East, US
« Reply #9 on: December 04, 2011, 06:44:53 pm »
Alot of times, you won't hear anything. You'll really never see sparks or anything. Usually the most you'll hear is a small pop. I would try discharging a couple of times. The second anode actually clips into the hole, so use the discharge tool to unclip it. The monitors do discharge over time, so the fact that you had the monitor off for a while should explain why you had no pop but its always best to be safe.
lilshawn
« Reply #10 on: December 05, 2011, 11:21:38 pm »
most modern flybacks (since pretty much the 80's) have a resistor network in them that bleeds off excess voltage.
unless your unit is old (pre 80's), the tube especially large (27, 30, 33"), or the flyback is damaged or compromised...
leaving the unit off for a few hours is often enough to get rid of the buildup in the tube.
yes, i said tube. It's not the electronics you have to worry about, it's the tube. it's construction is similar to a capacitor... a very high voltage, low capacity capacitor. google up yourself a set of plans to build a Leyden jar, then take a look at how a tube is constructed, they have more in common then you would think.
in closing, no. i don't know where you put your keys... oh right, no, you won't get zapped. but as an extra precaution, before you place the anode cap back on the bellybutton, hook up your discharge rig and touch the bellybutton to discharge it again, sometimes the charge starts to leak out of the glass and the tube builds up a bit of a charge again. then go ahead and snap the cup back on again.
Pro tip: turn the suction cup inside out and use it as a handle to clip the legs of the clip into the bellybutton.
calz
« Reply #11 on: December 22, 2011, 11:37:23 pm »
Thanks for the help guys. I FINALLY got this off (and lived)... started the cap kit yesterday. Was moving along fine until I hit C162... being anal, I thought I had some solder drip, and sucked it up and redid... now the solder won't take on either off the holes... thinking I messed up the board now  :cry:... I don't think there is any metal for the solder to ahere too. Thoughts?
mrazy1
  • Last login:December 31, 2011, 05:32:46 pm
« Reply #12 on: December 22, 2011, 11:54:01 pm »
Sounds like you sucked up the solder point around the hole..where the cap wires go. If so, Place the cap in the whole like you are going to solder it in. Find the nearest solder point where another component that is connected to that cap. come Thur the board and solder you cap wire to it making sure the wire isn't touching any other points. If your wire is too short you cant scrape the trace line next to the hole of the cap. and solder it there. either case I would Silicon that after soldiering.
Thanks Michael
calz
« Reply #13 on: December 23, 2011, 12:18:20 am »
Genius... awesome idea... thanks! I am a big amateur, and this is my first cap kit. So I can just solder this to another point that is closest to this one? I think that was the problem I was trying to solve, being that I did not know what I was doing… I thought I read that you needed to keep them from not touching other points so this is great. Can I do this to any point that is closest to this one even if it is already soldered? Just join them together? Sorry for the dumb questions… appreciate the help.
* Also forgot to mention this is the only non-polarity cap that I was replacing. I believe all off the others are P.
« Last Edit: December 23, 2011, 12:20:13 am by calz_01 »
mrazy1
« Reply #14 on: December 23, 2011, 12:41:04 am »
Well I know I didn't really explain it well. I was hoping someone else would had piped in.
If the trace line (traceline is the shiny lines running all over the back of the board going from one solder hole to the next) from that hole goes to another component You can just solder it to that component lead adding a little more solder to support the extra wire that is being added. The problem is that the wire can get moved and cause a cold solder connection so I glue down the wire, not the solder point, with silicone.
If youhave to go between other solder points that are not part of the traceline or component. then you have to protect that wire from touching those points.. You can use shrink tubing or black electrical tape. I believe in the industry they call this jumpering.  Merry CHRIST-mas I pray I answered all your concerns..
There is not dumb questions other then the one you dont ask. The unasked question are the one that causes problems. LOL I tell that to my kid.. But sometime we do not always know what question to ask.
Thanks Michael
calz
« Reply #15 on: December 23, 2011, 12:59:07 am »
Thanks for the excellent advice. I'lll give this a shot and see what happens... I was already out board shopping :-). Thanks again and have a GREAT holiday!
calz
« Reply #16 on: December 23, 2011, 11:04:25 am »
OK, so I took a look at the board and counld not figure out where I could solder this to. There does not seem to be any visible lines that I can tell where the next one is going to... There are other solder points close by but I am unsure if they are in the same path as this one.
mgb
  • North East, US
« Reply #17 on: December 23, 2011, 05:27:32 pm »
In this case its best to check the schematics. According to the 20ez schematic, one side of C162 goes to pin 23 of IC401 and the other side to R162.
heres the schematic http://arcarc.xmission.com/PDF_Monitors/Sanyo_%2020-EZV_(R-B)_Model_31_(1981-3-25).pdf
calz
« Reply #18 on: December 23, 2011, 07:57:05 pm »
Thank you. This helps a lot. Looks like the C162 capacitor wire will not reach over to IC401. The other side does reach R162 no problem. Would I need to run a wire or something and solder it to pin 23?
mgb
  • North East, US
« Reply #19 on: December 23, 2011, 10:10:59 pm »
Yeah You'd need to use a small piece of hook up wire. A small piece of cat5 would do. It may be best to see if there is a better place to intercept the trace coming from ic401 23 as it may be a pain soldering to the pin.
calz
« Reply #20 on: December 24, 2011, 11:16:07 am »
Thanks, yeah, I noticed that too... 23 is tiny and not sure how I would even do that. Sorry for the ignorance, but looking at the schematic I cannot determine another soldering point to use for this. Anyone have any ideas?
mgb
  • North East, US
« Reply #21 on: December 24, 2011, 04:55:00 pm »
Can't you just locate the trace where it would meet the solder pad, scratch off the green covering and solder the cap lead to that.
You should be able to do both connections from under the board (solder side).
I see that the connection to r162 is easy because its right next to it but also looking at the bottom of the board, you can see the traces.
If you're in doubt of having the correct trace, just meter it back to pin 23 and you should be good.
By doing this on the under side of the board, you should be able to not even have to use any small pieces of wire and you could just use the cap legs.
calz
« Reply #22 on: December 24, 2011, 11:51:34 pm »
Cool. Thanks makes sense. This is my first time doing this so was not aware that could be done. Thanks a ton for the advice. BTW - this looks much worse in a picture but also shows what a hack I was on this one :(.
lilshawn
« Reply #23 on: December 24, 2011, 11:55:56 pm »
looks like your soldering rig is WAY too hot.
you wouldn't by chance be using something like this would you??
http://www.elexp.com/solder/D650.jpg
mrazy1
« Reply #25 on: December 25, 2011, 02:23:54 am »
Haha I use the big one myself LOL. But the ones that dont get hot enough can cause that too. If you have to hold the iron on there for a long time to desolder then You will over heat the trace and mess up the board. I do use the big iron for desoldering and soldering. I use the a brasswick too which makes a differents and I can show you pictures of my work I have done and you cant tell I use a big iron like that one lilshawn posted LOL. but I am also a NASA certified solder and know when and how to solder. BUT that experience.
Thanks Michael
mgb
  • North East, US
« Reply #26 on: December 25, 2011, 10:33:12 am »
I use a 40 watt desolder tool. I can never seesm to get good results with a wick. And I use a small 15 watt iron for most soldering. I also use a butane iron for heavier stuff, its also what I use at work. Those adjustable units are very nice. I never seem to have much money when I need an iron so instead I buy cheaper ones, but I need them to be pretty portable because most of my work is done at peoples houses
calz
« Reply #27 on: December 25, 2011, 03:02:15 pm »
So the new soldering iron with adjustable heat is key... huge difference. I feel stupid for using the other one now. I cranked out a bunch of the other caps very cleanly with the new kit. Also, bit the bullet and ran a wire from C162 to IC401/23. Will post back either smoke or game play depending on the results :-). Thanks a ton for all of the help and suggestions.
mgb
  • North East, US
« Reply #28 on: December 25, 2011, 09:43:45 pm »
You live and you learn. The real mistake would be if you didn't learn from it.
I hope all works out well.
Remember to adjust your B+ voltage to 108 volts after finishing the cap kit
mrazy1
« Reply #29 on: December 26, 2011, 02:47:46 pm »
mgb I hear you there would like the soldering unit I had back in the day. Weller like calz_01 has but with the temp. posted.. so you knew what temp you was at. 40 watt isn't hot enough for wick. 60 or more is. with wick you heat up the wick more and since the solder need less heat it doesn't heat up the trace pad. I get great results. The problem with a sucker,I think, they dont always suck up all the solder the first time. you are always cleaning them out and burning up the tips. Adding heat directly to the pad and pin I think heats up the solder pad more and will cause it to lift more often then not BUT each to there own. We all have to figure out what works best for us.
Calz_1 I think you are doing a great job there looks good. cant wait to hear what the results are. GOD BLESS
Thanks Michael
calz
« Reply #30 on: December 26, 2011, 04:22:16 pm »
Thanks. I don't care for the solder sucker but could not find anything else in stock around here that would work as well. I have had to do this several times though to get the solder up which is pain.
So... I finished this up... all of the rest of the caps went in good. Put all back together, powered on and get a blank screen  :(. I can hear the power, but don't even hear the sounds or anything. Sounds like it is toally dead now. Before I did the cap kit the machine would boot, I could hear sound, but the screen looked like I first posted. Now nothing. Not sure what to look at next.... would just the monitor affect the rest of the machine booting and me being able to hear any sounds or anything? *frustrated*
mgb
  • North East, US
« Reply #31 on: December 26, 2011, 09:02:54 pm »
I'm sorry to hear that.
So the machine doesn't play blind or anything?
I'm not sure, is the main power fused and maybe the monitor blew the main power fuse somehow?
calz
« Reply #32 on: December 26, 2011, 09:36:25 pm »
Well if anything this has been a great learning experience :-). I was hearing power from the supply so did not think fuse and just checked it with my multi-meter and it is OK. But.... I saw there was a fuse on the monitor board and pulled that out for a test. It is no good, so I'll need to replace. Wondering if my cack job did something to trigger this or it got damaged when I moved it into my downstairs. I don't hear any sounds and cannot play blind so not sure what is up with that, unless it is tied to this. Hopefully I can get one of these fuses at Radio Shack or somewhere. Thanks again for the help an suggestions.
*Edit - also noticed that there is another fuse on the monitor board. Checked that one and it was fine as well. The one in question is labeled DC300MA on the circuit board.
« Last Edit: December 26, 2011, 09:45:19 pm by calz_01 »
mrazy1
« Reply #33 on: December 26, 2011, 11:07:43 pm »
 :banghead: Sorry to hear that. so after the cap kit now you got nothing :cry: and now you have blown fuses...  :hissy: if you blow more fuses on the monitor let us know.. could be that if it blows the fuse and the game doesn't play that that fuse is part of the PCB to that part of the monitor also that is bad.. and if bad then I would check EVERYthing over real good. Make sure everything got put in the right way and everything is connect right. other then that I dint know... Cap kit shouldn't have made it worse.
Thanks Michael
mgb
  • North East, US
« Reply #34 on: December 27, 2011, 09:54:33 am »
For some reason I didn't think of it before, but its doubtful your game boards are affected by something botched up on the monitor. The game may very well be playing blind but you can't hear it because the sound board is on the monitor.
calz
« Reply #35 on: December 27, 2011, 01:27:24 pm »
OK, some good news. I went and got new fuses this morning, installed, and can now see and hear gameplay - phew - THANKS for the advice. The monitor turns on as well, but the picture is very garbled. I tried some of the monitor adjustments but did not clear it up... sorry for all of the questions/problems about this :(.
calz
« Reply #36 on: December 27, 2011, 09:57:58 pm »
 :banghead: - messed with the monitor adjustments to no avail... can not get the picture to come up clean and wondering if this is a cold solder or something. Going to pull out the monitor board again (and discharge :() to see if I can find anything.
lilshawn
« Reply #37 on: December 27, 2011, 10:45:45 pm »
is this garbage moving around really fast or is it stopped?
i would check the sync and ground lines first anyways.
 i would also pull the board and check around where you where soldering for maybe a drip or a drop of solder bridging something it's not supposed to.
also since you where messing around that vert IC maybe there is a bridge or something going on there.
mgb
  • North East, US
« Reply #38 on: December 27, 2011, 11:05:23 pm »
Also, while I doubt its causing the problem you are currently looking at, but make sure to check and adjust the b+ voltage to 108 volt dc.
mrazy1
« Reply #39 on: December 28, 2011, 12:15:25 am »
Yea this looks like a sync problem. I would answer the questions Lilshawn asked and do.but I would also Check video plug. wiggle it to see if it clears up or stay the same. play with the Plug at the PCB. Check ground wire. before pulling monitor out.
Thanks Michael
