Author Topic: Arcade VGA 3000 and Monitor issues/questions  (Read 2284 times)
cveile
  • Last login:October 11, 2012, 07:19:13 pm
« on: October 13, 2011, 10:41:37 pm »
I bought a mame cabinet...It has a LG Philips a48qad220x horizontal monitor in it...I'm a relative noob to configuring this stuff and whatnot...
It had an older pc with the old AGP  avga card in it and it worked well, but was a little (or a lot) slow, especially for newer games...I'd since decided to upgrade the hardware and do the PCIe AVGA 3000....I built a new pc in the cab, installed xp media center...Copied over the Mameuifx folders and other emulators...
So...first thing I noticed was that there was more flickering on interlaced modes (XP desktop, mame games where I had the ini's set to stretch at 640x480)....The whites of the screen seem to be most notable on the flicker...The other emulators (non mame) also appeared to flicker...I haven't checked on all those yet, but am guessing I had them at 640x480 stretched possibly and that's why there is the flicker.
So...I have a couple of issues:
1) more flicker with new card/cpu. Is there any way to address it? At times the white text on Maximus is hard to read...Sometimes impossible on XP...XP's not a big deal, but the FE and other emulators are a concern
2) Ms Pac man and other vertical games are cut off at the top & bottom, I've tried some different resolutions and configurations. I thought from the Ultimarc site that the 352x288 should work, but no luck.  (also tried grooovymame and still experienced screen cutoff with no default ini files for the games and the default groovymame mame.ini)...Used Mamewah's mame resolution tool to test....
So...my current main concern is getting the classic vertical games to work on my cab again...below is my mamuifx mame.ini. Is there anything obvious that eeds changed?  Also, what settings do you have that work for Ms Pacman in case I can try something with that??
Thanks again for helping me out!
Below is the Mame,ini for mameuifx:
<UNADORNED0>
# CORE CONFIGURATION OPTIONS
readconfig                1
# CORE SEARCH PATH OPTIONS
rompath                   roms
samplepath                samples
artpath                   artwork
ctrlrpath                 ctrlr
inipath                   ini
fontpath                  .
cheatpath                 cheat
crosshairpath             crosshair
# CORE OUTPUT DIRECTORY OPTIONS
cfg_directory             cfg
nvram_directory           nvram
memcard_directory         memcard
input_directory           inp
state_directory           sta
snapshot_directory        "E:\Emulators\EmuMovies Downloads\MAME\Snap"
diff_directory            diff
comment_directory         comments
hiscore_directory         hi
# CORE STATE/PLAYBACK OPTIONS
state
autosave                  1
playback
record
mngwrite
aviwrite
wavwrite
snapname                  %g/%i
snapsize                  auto
snapview                  internal
burnin                    0
# CORE PERFORMANCE OPTIONS
autoframeskip             0
frameskip                 0
seconds_to_run            0
throttle                  1
sleep                     1
speed                     1.0
refreshspeed              1
# CORE ROTATION OPTIONS
rotate                    0
ror                       1
rol                       0
autoror                   0
autorol                   0
flipx                     0
flipy                     0
# CORE ARTWORK OPTIONS
artwork_crop              0
use_backdrops             1
use_overlays              1
use_bezels                1
# CORE SCREEN OPTIONS
brightness                1.0
contrast                  1.0
gamma                     1.0
pause_brightness          0.65
# CORE VECTOR OPTIONS
antialias                 1
beam                      1.0
flicker                   0
# CORE SOUND OPTIONS
sound                     1
samplerate                24000
samples                   1
volume                    0
# CORE INPUT OPTIONS
coin_lockout              0
ctrlr
mouse                     1
joystick                  1
lightgun                  1
multikeyboard             0
multimouse                0
steadykey                 0
offscreen_reload          1
joystick_map              auto
joystick_deadzone         0.3
joystick_saturation       0.85
natural                   0
uimodekey                 auto
# CORE INPUT AUTOMATIC ENABLE OPTIONS
paddle_device             keyboard
adstick_device            keyboard
pedal_device              keyboard
dial_device               keyboard
trackball_device          mouse
lightgun_device           mouse
positional_device         keyboard
mouse_device              mouse
# CORE DEBUGGING OPTIONS
log                       0
verbose                   0
update_in_pause           0
debug                     0
debugscript
debug_internal            0
# CORE MISC OPTIONS
bios
cheat                     0
hiscore                   1
skip_gameinfo             1
confirm_quit              0
# WINDOWS DEBUGGING OPTIONS
oslog                     0
watchdog                  0
debugger_font             "Lucida Console"
debugger_font_size        9
# WINDOWS PERFORMANCE OPTIONS
priority                  0
multithreading            1
numprocessors             auto
# WINDOWS VIDEO OPTIONS
video                     ddraw
numscreens                1
window                    0
maximize                  1
keepaspect                1
prescale                  1
effect                    none
waitvsync                 0
syncrefresh               0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch                 0
# DIRECT3D-SPECIFIC OPTIONS
d3dversion                9
filter                    1
# PER-WINDOW VIDEO OPTIONS
aspect                    auto
resolution                auto
screen0                   auto
aspect0                   auto
resolution0               auto
view0                     auto
screen1                   auto
aspect1                   auto
resolution1               auto
view1                     auto
screen2                   auto
aspect2                   auto
resolution2               auto
view2                     auto
screen3                   auto
aspect3                   auto
resolution3               auto
view3                     auto
# FULL SCREEN OPTIONS
triplebuffer              0
switchres                 1
full_screen_brightness    1.0
full_screen_contrast      1.0
full_screen_gamma         1.0
# WINDOWS SOUND OPTIONS
audio_latency             2
sound_resync              0
# INPUT DEVICE OPTIONS
dual_lightgun             0
joystick_id_1             0
joystick_id_2             1
joystick_id_3             2
joystick_id_4             3
joystick_id_5             4
joystick_id_6             5
joystick_id_7             6
joystick_id_8             7
