Author Topic: Need help removing paper from NOS bezel!  (Read 2004 times)
RUP
  • Last login:August 13, 2013, 09:21:12 am
« on: October 10, 2011, 09:13:56 pm »
Hi all, Does anyone have any tips on removing the protective paper coating from an old plexiglass bezel?  I can only get the stuff to peel in very tiny strips.   I googled it but a lot of the ideas suggest some goo gone or other stripping agent.  I don't want to destroy the finish or the artwork on the other side!  Thanks
Ortizimo
  • Last login:July 10, 2024, 07:26:45 pm
  • USAF Retired Veteran (1995-2015)
Re: Need help removing paper from NOS bezel!
« Reply #1 on: October 11, 2011, 06:56:40 am »
yes, i used thinner gel not the liquid. The gel doesn't run and you can leave it there for 5 minutes then scrape with a spackle. I've done it before and didnt damage anything. Good luck.
« Last Edit: October 11, 2011, 06:58:45 am by Ortizimo »
Sometimes, when it's quiet, I can still hear the monkeys." - Guybrush Threepwood, Mighty Pirate.
RUP
« Reply #2 on: October 12, 2011, 10:57:24 pm »
Thanks! I ended up using denatured alcohol.  I SOAKED the paper let it sit for 5 minutes or so and it peeled right off with no harm to the painted artwork on the other side!
rikitiki
  • Last login:January 03, 2020, 01:17:35 pm
    • Custom Arcade Game Printing
« Reply #3 on: October 19, 2011, 11:48:41 am »
careful denatured alcohol WILL attack some silkscreened inks.
Id recomend NAptha for something like this in the future.
Saving the Planet one Game at a time.
www.ThisOldGame.com
RUP
« Reply #4 on: October 26, 2011, 08:02:00 pm »
Wow, guess I got lucky this time!  Thanks for the tip I'll be sure to use that next time! Where can you get Naptha?  Can you pick it up at a Home Depot or Lowes?
rikitiki
« Reply #5 on: October 27, 2011, 11:08:46 am »
Both Its a great all around cleaner as well and is ery usefull in cleaning surfaces before art applications
www.ThisOldGame.com
