Author Topic: singe games wont display  (Read 3560 times)
adidas1984x
  • Last login:January 06, 2023, 07:14:53 am
« on: September 16, 2011, 02:25:26 pm »
Singe games on my mame cabinet the screen is jumpy and I dont know why. Im using a 15khz arcade monitor and its connected to a pc with arcade vga card, and using a jpac. on the pc monitor the game plays fine but on arcade the screen jumps im using singe v1.0
BobA
  • What Me Worry?
Re: singe games wont display
« Reply #1 on: September 16, 2011, 07:25:34 pm »
What is singe?   Is it the Daphne related program?
adidas1984x
« Reply #2 on: September 19, 2011, 02:33:50 pm »
it helps play old laser disc shooters arcade style
9innail
  • Last login:September 22, 2011, 11:18:53 am
« Reply #3 on: September 20, 2011, 08:19:27 am »
What files are need to play Singe games.Are they the same type of mpgs as Daphne?  :dizzy:
Thanks.
« Reply #4 on: September 20, 2011, 09:55:03 am »
It's built around Daphne and makes the light gun games more like the original arcade versions by adding coin input and the original score overlays.
It can also play time traveller and some kind of old vhs tape based games.
(singe is taken from the name of the dragon in dragon's lair)
There's some more info in this thread, but the links to the singe section of the daphne forums don't seem to work anymore:
http://forum.arcadecontrols.com/index.php?topic=105956.0
Sorry adidas1984x, nobody seem to have an answer for you.  :-\
adidas1984x
« Reply #5 on: October 26, 2011, 11:49:28 am »
headkaze
  • Last login:July 05, 2026, 01:56:04 pm
  • 0x2b|~0x2b?
« Reply #6 on: October 26, 2011, 12:32:55 pm »
Check out the command line options for Daphne here. There are various graphics related options you can try.
adidas1984x
« Reply #7 on: October 28, 2011, 07:48:11 am »
not quite sure how to do that but where on singe do I do that
headkaze
  • 0x2b|~0x2b?
« Reply #8 on: October 28, 2011, 11:10:28 am »
I don't know anything about Singe but if it's this there is a timetraveller.bat with the following line:
Code: [Select]
@daphne.exe singe vldp -x 640 -y 480 -framefile singe/timetraveler/frame_timetraveler.txt -fullscreen singe/timetraveler/timetraveler.singe
That would be where you could add the command line options.
