Author Topic: 3 scrolling images?  (Read 1885 times)
Gazlaz
  • Last login:September 11, 2011, 08:43:36 pm
3 scrolling images?
« on: August 25, 2011, 04:58:49 am »
Hi my screen is split into 3 images (convergence?) and scrolling up (vhold?).
I am a total noob so I would appreciate some help if possible.
I have a Kortek K1-2-V0, connected to a jpac with a radeon 3200 and soft15Khz mod and res set to 640x480.
I have searched the web but I cant find a fix  :'(
lostinarcade
  • Last login:December 18, 2024, 06:16:52 pm
Re: 3 scrolling images?
« Reply #1 on: August 29, 2011, 05:50:05 pm »
u have a picture?
i also used 15 khz and i had a problem where the screen was wrong... my resolution was 640 x 480. so i installed powerstrip and i picked the arcade setting and bam it worked.
Gazlaz
« Reply #2 on: September 05, 2011, 05:29:51 am »
Hi I have tried power strip but still no good...I have added a screenshot if this helps.
I have spare neck boards for this monitor i may try as the one that is on it has been previously repaired, if that doesn't work I might dump the monitor and put an old TV in there.
Any help would be greatly appreciated...thanks.
lostinarcade
« Reply #3 on: September 05, 2011, 09:21:00 pm »
maybe try the custom drivers for ati? if that dont work then i dont know sure someone here might be able to help u...
http://mame.groovy.org/WindowsATIDrivers/
lostinarcade
« Reply #4 on: September 05, 2011, 09:25:04 pm »
oh yea also. if u put the jumpers on 31 and 15 Khz do u get a split screen that u can atleast make out what it is?
is your jpac hooked up to the keyboardplug or usb for power (depends what version u have)?
did this monitor work correctly with a original arcade board...?
BobA
  • What Me Worry?
« Reply #5 on: September 06, 2011, 12:51:05 am »
It looks like a sync problem to me.  What H and V sync do you have connected?
Gazlaz
« Reply #6 on: September 06, 2011, 03:21:20 am »
Hi, I have no idea what H/sync or V/sync is converted sorry. I played with a h hold button and got a better image (attached) but the screen is still slit into 2.
Gazlaz
« Reply #7 on: September 07, 2011, 03:03:01 am »
Well I finally have 1 image on the screen, I uninstalled soft 15khz (31khz) and just left the first option installed (15khz) it worked well! I now only need to adjust the blurriness and slight flicker, then I can map my controls and I will be a very happy youngish man!
Thank you Lostinarcade and BobA I really appreciate your help :cheers:
