Author Topic: Is Particleboard okay if I'm using laminate over it?  (Read 1989 times)
upper2bits
  • Last login:December 20, 2011, 05:52:45 pm
« on: July 30, 2011, 10:02:44 am »
I want the t-molding to line up and I can't find 5/8 mdf or plywood so I'm stuck with Particleboard.  If one side will have laminate is Particleboard okay to use?
upper2bits
Re: Is Particleboard okay if I'm using laminate over it?
« Reply #1 on: July 30, 2011, 10:06:20 am »
Actually, doing a little more reading it it appears that the laminate is only 1/32" think so 3/4 MDF with that might fit with 3/4 t-molding.  No?
upper2bits
« Reply #2 on: July 30, 2011, 10:20:49 am »
More reading, would it work to just use 3/4 mdf, 1/16 laminate and then get 13/16 tmodling?
JRChristenson
  • Last login:August 28, 2020, 05:29:39 pm
« Reply #3 on: July 30, 2011, 11:56:26 am »
I used particleboard for my painted bartop and it's coming out fine. I would definitely use it if I was laminating, much cheaper than mdf or plywood.
Knightlore
  • Last login:June 04, 2014, 07:44:55 am
« Reply #4 on: July 30, 2011, 12:02:16 pm »
Well I took delivery a few weeks ago of a pre-build cocktail cab, it's laminated particle board (or chipboard as we call it over here) and it's absolutely fine, very sturdy indeed.
syph007
« Reply #5 on: July 31, 2011, 09:51:32 am »
my experience is that it is just ok.  The edges of it have a tendency to crumble.  I now only use it for mockups or templating.  MDF holds up better, but its nastier to work with, which is why I use particle board still for some jobs.  Routing the t-molding slot in particle board wont leave as nice of slot as other material.  But yes it will be covered up.  So I guess its probably fine, but I wouldnt recommend.
Edit:  Looks like pinballjim is using particleboard.  See the edges for what I was talking about.
http://forum.arcadecontrols.com/index.php?topic=113417.0
« Last Edit: July 31, 2011, 09:54:23 am by syph007 »
