Author Topic: Removing insides  (Read 1481 times)
chaos11624
  • Last login:August 23, 2011, 12:02:20 pm
Removing insides
« on: July 29, 2011, 04:04:48 pm »
I have what was told was a mortal combat cab converted to a 4 player NBA hangtime.
The monitor image gets clipped, so I'm going to swap out for a 27 inch LCD monitor.
I understand the discharge I need to do, just had a few questions about other components .
Once discharged am I safe handling the chassis to remove , the neck board and psu, I've read some that say if you are just pulling everything , there is no need to discharge as your not popping the anode cap off, any insight would be helpful as I have the first time jitters, I know it won't kill me just looking to avoid the bite.
Thanks again, also if anyone in San Diego wants to take the monitor and chassis off my hands it's yours to haul away, it works and could be tweaked  I'm sure
Mikezilla
Re: Removing insides
« Reply #1 on: July 29, 2011, 05:41:46 pm »
Hey man, I cant tell you too much about the discharge aspect of it, and all that, but what part of San Diego are you? If youre not too far, Ill be happy to take it off your hands.  ;D
chaos11624
« Reply #2 on: July 29, 2011, 05:52:22 pm »
I'm in Mira Mesa
chaos11624
« Reply #3 on: July 30, 2011, 03:26:06 pm »
I pull it all out successfully, anyone wants this monitor hit me up, I could never identify it but it is a 15/25 hz 25 inch monitor
Mikezilla
« Reply #4 on: August 01, 2011, 11:22:24 am »
Cool Im in Mission Valley, MM isnt far. Think maybe I can pick it up from you on friday?
