Author Topic: Volume control knob for PC Speakers  (Read 9054 times)
emb
  • Last login:September 14, 2018, 02:01:19 pm
    • Don Honerbrink
« on: July 06, 2011, 12:42:25 pm »
I plan on adding a volume control knob for a pair of PC speakers to my cabinet.
Does anyone know where I can find a volume control knob (adapter) that takes in a 3.5mm jack and sends out a 3.5 mm jack?
I could solder one up but figured why waste the effort if there is one already out on the market.
syph007
Re: Volume control knob for PC Speakers
« Reply #1 on: July 06, 2011, 12:45:03 pm »
replied in your delere me thread, before i noticed it was in wrong forum.
Reposted here
This post helped me make one.  I just bought the pot and a 3.5 extension, and located the pot in the middle, then found a shiny knob.
http://scarvell.net/wiki/index.php?title=VOLUME_CONTROL_MOUNTING_AND_WIRING
emb
    • Don Honerbrink
« Reply #2 on: July 06, 2011, 12:52:19 pm »
Reposted here
Thanks for that link, although I am looking for a pre-built solution. If there isn't one, I can solder one up.
« Reply #3 on: July 06, 2011, 01:25:09 pm »
Would something like this work?
http://www.radioshack.com/product/index.jsp?productId=2102975&CAWELAID=107594003
I know it's not a knob, but I didn't know if that was important
emb
    • Don Honerbrink
« Reply #4 on: July 06, 2011, 01:30:22 pm »
This is "very close" to what I am looking for, except with a knob for the reason since it will be mounted on the control panel.
« Reply #5 on: July 06, 2011, 01:33:42 pm »
A bit spendier, and you would have to get adaptors from 6.3 down to 3.5, but here is one with a genuine knob. Unfortunately, the knob is right on the jack instead of on the line. It might make mounting a bit difficult.
http://www.sweetwater.com/store/detail/VCable250-10?utm_source=CSE&utm_medium=PPC&utm_campaign=none&utm_term=VCable250-10-V-Cable_250k_10&SID=0&zmam=89202644&zmas=1&zmac=1&zmap=VCable250-10
Edit: Actually now thinking about it, a guitar cable would only be mono. Nevermind. :-\
« Last Edit: July 06, 2011, 01:40:42 pm by Vigo »
scofthe7seas
  • Last login:January 10, 2012, 11:33:10 am
  • I'm Eskimo. There's nothing here.
« Reply #6 on: July 06, 2011, 01:44:00 pm »
I wonder if you can take off that knob and put another longer stemmed one on.
syph007
« Reply #7 on: July 06, 2011, 01:52:31 pm »
Reposted here
I tried to find one just as you are describing and never could so I had to make one.  You really want a panel mount pot anyway, and I doubt that exists prefabbed, or at least I wasn't able to find.  It was very easy to make even for me :D
emb
    • Don Honerbrink
« Reply #8 on: July 06, 2011, 01:57:31 pm »
Reposted here
I am an electrical computer engineer and have pots lying all over the place from back in college. I don't mind soldering one up, I just figured it would save me a little time to order one.
emb
    • Don Honerbrink
« Reply #9 on: July 06, 2011, 01:58:07 pm »
Yea, I think I will just solder one up. Thanks for everyones help.
scofthe7seas
« Reply #10 on: July 06, 2011, 02:00:18 pm »
I was just thinking about this, your PC speakers should already have a volume knob on them. All you have to do is basicallyclip the thing off, and put a set of wires on there as extentions. then you can replace the current (presumably) smaller knob with a bigger one from Radio Shaq.
syph007
« Reply #11 on: July 06, 2011, 02:39:34 pm »
Reposted here
I had a bunch too, but didn't have a dual gang ones.  The electrical supply place near me, even had a good selection of knobs.  :D
Cynicaster
« Reply #12 on: July 07, 2011, 11:12:40 am »
The PC speakers I'm using on my cabinet have a volume control right on the front of the right speaker.  I decided a simple volume control solution would be to just use that.  My speaker grilles are mounted with magnets, so it's simple to pull it off, adjust the dial, and replace.
Kind of a crude approach, but honestly, it made no sense to me to have any kind of control visible on the outside of the cabinet for something that is used so rarely.
emb
    • Don Honerbrink
« Reply #13 on: July 07, 2011, 01:30:36 pm »
Well, it looks like I don't have any dual ganged pots in my arsenal.
Does anyone who has used dual-gang pots for their speakers have any recommendations on which one to buy? I'm looking to having the shaft go through 3/4 inch thick wood.
emb
    • Don Honerbrink
syph007
« Reply #15 on: July 07, 2011, 09:16:38 pm »
As long as that's a logarithmic.not linear, you're good to go.  Im sure you can find one online at digikey or other.
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« Reply #16 on: July 09, 2011, 09:24:57 pm »
