Author Topic: DIY Arcade Help & Ideas Welcome  (Read 2667 times)
comicsans
  • Last login:June 29, 2012, 05:03:49 am
« on: June 28, 2011, 02:55:25 pm »
http://cgi.ebay.co.uk/ARCADE-CABINET-MACHINE-KIT-DIY-FLAT-PACK-MAME-2-PLAY-/180681431552?pt=UK_Video_Games_Coin_Operated_MJ&hash=item2a1173da00
I'm thinking of picking this up to do the Xbox 360 bar top i have been wanting to do for a while. I was thinking about completely deceasing the 360 add fans ect and put it inside
also i was thinking for the controls deceasing the mad catz street fighter stick as it can be upgraded easily with sanwa buttons.
Has anybody bought one of these? also i have noticed due to size restrictions of the build i could only fit a 19" Monitor in which is a problem because I will need something with a
hdmi input to get the best picture it seems most monitors under 23-24" don't have hdmi.
Anyone got any ideas on what im planning?
gabe
  • Last login:September 10, 2012, 12:44:38 pm
Re: DIY Arcade Help & Ideas Welcome
« Reply #1 on: June 28, 2011, 04:47:51 pm »
Quote from: comicsans
Let us observe a moment of silence for the deceased. R.I.P.
comicsans
« Reply #2 on: June 28, 2011, 04:56:55 pm »
ooops de-casing.....
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #3 on: June 28, 2011, 05:08:57 pm »
I decased a decesead 360 to fix it  :-\
No need to add a bunch of fans.  The standard fan should work fine as long as there is a big vent in the back.
I would get the mad catz fight pads from vpgames.com, they are only 23 bucks a pop and easy to hack, that is what I did.
You don't need HDMI, just get vga cable for the xbox, you can find one on ebay for under ten bucks, once again, this is what I did...
BobA
  • What Me Worry?
« Reply #4 on: June 29, 2011, 12:51:10 am »
Did you notice that the kit seems to be made of PVC foam board?   I would like to know how strong it is.
comicsans
« Reply #5 on: June 29, 2011, 03:06:31 am »
heres a video of a completed project
comicsans
« Reply #6 on: June 29, 2011, 03:09:51 am »
ChurchOfSolipsism
  • Last login:May 09, 2023, 01:43:39 pm
« Reply #7 on: July 01, 2011, 08:28:49 am »
+1. If you throw the buttons away anyway then all you're left with is a PCB and a stick that, from what I've heard, is a tad on the crappy side. Get a Japanese quality stick from Sanwa or Seimitsu and buy what donkbaca recommended or one of these for an easy-to-solder-to PCB:
http://www.amazon.co.uk/Arcade-Games-Stick-Xbox-360/dp/B000MCHETQ/ref=sr_1_15?ie=UTF8&qid=1309523229&sr=8-15
comicsans
« Reply #8 on: July 01, 2011, 09:16:43 am »
ive got a mad catz se which you can mod up with sanwa parts so im going to take it out of the case and use the top as a template on the control panel.
i should get the kit tommrow so i will take pictures and start a project thread. I am a bit worried about screwing into the control panel if its pvc ill have to see when it comes.
SavannahLion
« Reply #9 on: July 01, 2011, 04:57:11 pm »
If it's the stuff I'm thinking of, it's supposed to be very strong. I believe it's often used in outdoor signage?
