Author Topic: need help diagnosing monitor updated w/pics  (Read 1615 times)
roguetel
  • Last login:June 08, 2013, 02:27:58 pm
  • arcade nostalgia, more addictive than heroin
« on: June 01, 2011, 05:03:46 pm »
*UPDATE*So the replacement monitor has some problems anyway, attached are pics of what it looks like, both an unidentified game atrract and the icade 60/1 selection screen. You Guys who know who what they're doing any suggestions? cap kit  or trash?
Hi guys noob here, but I like to try to do it myself, The cab is an original afterburner upright with the original boards.
Old original monitor completely broken, it was labeled goldstar on the side. Replacement monitor is a wells gardner 19k4625. R,G, and B makes sense except for the + vs. - argument on the replacement monitor. Any help is much obliged.
Old monitor had:
R
G
B
GND
HS
VS
New monitor has:
R
G
B
GND
POS VS
POS HS
GND
NEG VS
NEG HS
« Last Edit: June 01, 2011, 07:39:46 pm by roguetel »
grantspain
Re: need help diagnosing monitor updated w/pics
« Reply #1 on: June 02, 2011, 06:53:04 pm »
sync should be on neg hs
if you still have slightly scrambled picture then adjust the frequency pot which is located on the daughter board-accessible from the side by long terminal blade type screwdriver
roguetel
« Reply #2 on: June 02, 2011, 10:18:07 pm »
HI thank you for your time grantspain, this is the white one visible on the input board in the posted pic of the WG, right?
Any input on the garbled video the monitor is giving in the third and fourth pics? It's definitely not an adjustment issue I'm just wondering if this is what cap kits or trash bins fix.. :dunno
« Last Edit: June 02, 2011, 10:20:33 pm by roguetel »
grantspain
« Reply #3 on: June 03, 2011, 02:29:54 am »
nah,its the hidden pot in the centre of the board
http://www.arcaderestoration.com/index.asp?OPT=3&CBT=24
roguetel
« Reply #4 on: June 03, 2011, 08:19:53 pm »
grantspain, thank you so much for your help :applaud:. Tweaking that red pot and watching that scrambled screen come together was an amazing feeling.  :cheers:
Afterburner is getting a work out tonight!
