June 10, 2026, 12:17:54 am
You can still find wico sticks. Put up a wanted post here or klov. The 4" sticks are being reproed right now and should be available soon. Everything else is the same on the 8-way wicos, so you can buy a 3.5" and swap to the 4" stick.
Depends on which games matter most. Robotron was the only one with the tall sticks, I believe. They normally have a 3.5" shaft. The defender stick is its own animal, it is a steel 2-way. If you do want the 3.5" shafted model, thats what I have available. They both have NEW shafts and NEW grommets, which is very important. Don't pay $25 for a worn out assembly with a rusted shaft. Unless you just like throwing money away
I am thinking of buulding a multi Williams using this particualr CPO:http://www.thisoldgame.com/products/mult-williams-defender-versionI really like the look of that CPO as it is mainly the look of Defender. Other multi Williams I have seen seem too cluttered. Anyway I digress....My main query is are there any good replacement sticks for Robotron etc? I know the originals Wico sticks are now obsolete. But are there any leaf switch joysticks out there that are pretty close to the look and feel of the originals? Or am I wishing for too much?
Quote from: Paul Olson on April 11, 2011, 05:45:09 pmYou can still find wico sticks. Put up a wanted post here or klov. The 4" sticks are being reproed right now and should be available soon. Everything else is the same on the 8-way wicos, so you can buy a 3.5" and swap to the 4" stick. Good news, where will these be available from?, so that I can keep an eye out for when they are available. .
