Author Topic: Failed Projects  (Read 3066 times)
SavannahLion
Failed Projects
« on: March 22, 2011, 11:02:25 am »
For those who create beAutiful cabs, how many of you attempted a design only to have it not turn out or discarded a design because of some design constraint you couldn't overcome?
I have (had) a project I was nursing for a year but couldn't get the design plans down right. I couldn't get the measurements right. Been trying Sketchup but there's a compound curve I couldn't get right. Two days ago I realized I could create the compund curve using vectors and slicing it, like a cat scan. Then assemble the slices in the real world by printing it up and using it as a template to carve from. I printed the first layer and it dawned on me why I was having a hard time getting the numbers to fit. The thing is f'ing HUGE! Nearly twice the size I wanted. I doubled checked the measurements I plugged in to create the vector and they're right.
Aaargh! Now I feel like ass, my pet project is looking more and more like a still born. :(
ark_ader
  • I glow in the dark.
Re: Failed Projects
« Reply #1 on: March 22, 2011, 04:49:39 pm »
I used to like making small cabs out of laptops, but instead of giving them to people, I smashed them up.
I realised that my wood working was complete utter crap, and I was better off buying from the experts.
Now I'm stuck with boxes of laptop parts, and amassed cables and junk.
I would say (except for 5) most of my projects were failed ones.   :laugh2:
AtomSmasher
    • Atomic-Train
Re: Failed Projects
« Reply #2 on: March 22, 2011, 06:43:45 pm »
I have a half-finished hidden door bookcase sitting in my garage.  I never could get the molding to look right, so it was always too obvious that it was a door.  I always meant to go back and figure out a way to make it work, but I never did.  I think I just need to change to a different type of hinge.
I just looked up the thread I made on the project and my reaction was "Holy crap, that was 2007"  I didn't think it had been that long.
Anyways, here's the old thread for prosperity, maybe one day I'll actually finish it.   http://forum.arcadecontrols.com/index.php?topic=64170.0
Donkbaca
    • Slim built MAME/Xbox cab
Re: Failed Projects
« Reply #3 on: March 22, 2011, 07:46:00 pm »
That is dope!  I think all you would need to do to fix it is:
1) Change the molding.  If you look at the hidden doors website place in you thread,  all the book cases have simple, flat side molding, and some sort of lavish crown molding.  I think having designs at the four corners like you do make it look like a door.
2) The door has to hang lower.  It needs to look like its resting on the ground
As for my failed projects? hmm, Hopefully not my cab :)  though I have come close to screwing things up pretty bad..
hypernova
  • Last login:November 25, 2016, 12:52:48 pm
Re: Failed Projects
« Reply #4 on: March 22, 2011, 09:33:10 pm »
I put my 3/4 players at a 45 degree angle.
Damn it.  I'm too lazy to fix it, because one: it doesn't get played enough, and two: It's a 4P panel with LEDs on all buttons, and they're all leaf switches, and it would require rerouting the joystick hole, which would be a huge mess.  So screw it.  Live and learn.
I'll exercise patience when you stop exercising stupidity.
My zazzle page.  I've created T-shirts!
SavannahLion
Re: Failed Projects
« Reply #5 on: March 23, 2011, 01:31:13 am »
My father was a carpenter so I remember more than a few houses with some hidden surprises. Some of the ones that I can recall.
A crawl/storage space between the (steep sloped) roof and the wall. The access panel actually had two light fixtures mounted. To open it, you simply pulled on the light fixtures. I discovered it purely by accident when the owner was moronic enough to leave the panel aside. The panel was held in place by magnets and the magnets completed the circuit. Probably wouldn't pass inspection now that I think about it and probably unwise to leave the switch powered on when you're working around it.
A hidden hatch panel that opened up into crawl space between the walls. Climb the ladder and it led you into a hidden area in the attic. Basically, you had to, IIRC, start on the 1st floor, crawl past the 2nd (and 3rd?) floor until you reached the attic. I don't remember how many floors it went up. When I was older, I used to have nightmares about this one transposing that house onto my fathers workshop so the details are sketchy at best. Not sure why I had nightmares about it.
A faux rock wall that opened up into a simple shelving unit.
A disused dumbwaiter whose doors were paneled over in dark wood giving the illusion nothing was there. Kind of dumb IMHO, but whatever. IIRC, the house later burned to the ground.
The house I grew up had this feature (trim was added last year so the illusion is ruined now), but I recently saw a similar door in an upscale neighborhood that put what my father built to shame. The siding (on my house was set at a 45 degree angle, on the upscale house vertical) on the house went through the door. In other words, the siding was installed on the door itself. With no trim and only the door handle to indicate any sort of opening. However, on the upscale house, the damn door was twice as wide and, by my estimates about two floors high. Except for the lone door handle and the stair steps, I had no idea the door was even there. I also strongly suspect the entire side of the house opened up to allow direct access to the front yard pool. I've tried to find the house again but to no avail. The neighborhood is confusing as hell. :(
A house that actually had two subbasements. Access to the first was gained by a simple stair. Access to the second was done by pushing the stairs up to reveal another set of stairs going down. How one manages to get furniture down something like that is beyond me.  :dizzy: It was unfinished at the time, so I don't know if it was any concern.
Not really a "secret" but I encountered a mirrored wall that opened up in an accordion fashion. Not really a secret because you can see the spaces between the mirrors and wall. It just didn't have any trim. I always thought that was an interesting idea to pursue.
That kind of stuff always fascinated me. Probably why I love places like Winchester Mansion so much.
  • Last login:June 19, 2026, 12:33:17 am
Re: Failed Projects
« Reply #6 on: March 23, 2011, 02:12:11 am »
My infamous cylindrical cocktail cabient comes to mind.
I figured it woudl be cool to make a cocktail cab that wasn't as boxy.  I was going to put a rail around the base, letting me have multiple control panels that I could slide into position. 4-player as well, since at the time, many 4-player cocktail games had been added to mame. I couldn't overcome the design flaw of using a 19 inch monitor on a cylinder that was really only meant to be about 20 inches.  Expanding it to the point of where it would have been structurally sound ruined the looks, so I took it apart.
Monitor has a new home in a really nice cabinet I'm currently in the process of finishing.
AtomSmasher
    • Atomic-Train
Re: Failed Projects
« Reply #7 on: March 23, 2011, 02:25:35 am »
Dialing the wayback machine to early 2006, I come across a project that never made it past the planning stages.  It was a dining room table with a hidden arcade inside.  I doubt I will ever come back to this project, at least not any time soon.
http://forum.arcadecontrols.com/index.php?topic=50651.0
SavannahLion
Re: Failed Projects
« Reply #8 on: March 23, 2011, 10:59:14 am »
Yeah, I had an idea for a round cocktail too. I went through several iterations before I dropped the idea.
  • Last login:Yesterday at 12:10:33 pm
Re: Failed Projects
« Reply #9 on: March 23, 2011, 05:24:34 pm »
I built a 3rd CP on my cocktail cabinet (first project).  I never quite finished it because I hate the 3rd CP and now the cab is gutted.  One day I want to finish it but I will need to think of an elegant way to chop off the 3rd CP and still have it look nice.
Donkbaca
Re: Failed Projects
« Reply #10 on: March 23, 2011, 05:27:51 pm »
I say convert the 3d cp into a nice planters box
Re: Failed Projects
« Reply #11 on: March 23, 2011, 05:31:58 pm »
That might work.  If anything it will make for a nice view while playing some head-to-head Hit The Ice!
Gray_Area
  • -Banned-
  • -Banned-
Re: Failed Projects
« Reply #12 on: March 25, 2011, 12:52:40 am »
This has me thinking of a large cable spool.
-Banned-
ark_ader
Re: Failed Projects
« Reply #13 on: March 25, 2011, 10:52:46 am »
I had a plan on making a cocktail that had a electric set train built in (N Scale).
Not a conventional cocktail, but a display case like table.
whammoed
  • Last login:Yesterday at 11:12:06 am
  • Crack don't smoke itself
    • NiceMite
Re: Failed Projects
« Reply #14 on: March 25, 2011, 12:37:36 pm »
Is it oak plywood or similar?  If so just remove the panel, fill any holes, and adhere real wood veneer on top.
