Author Topic: Hidden Door Bookcase - New Project  (Read 52859 times)
AtomSmasher
    • Atomic-Train
« on: March 10, 2007, 10:07:09 pm »
When I was a little kid, there were a number of things that I always thought would be awesome to have when I get older.  So far I have gotten everything on that childhood list except one.  My own arcade cabinet - check.  A muscle car - check.  A projector for a giant TV - check.  Hidden doors in my house - not yet.   I admit that its a petty list and I probably should of wanted something more substantial, but I was an odd kid.  Actually I'm still that same odd kid, just a bit older and now have more resources at my disposal.
Now it is time to check that final item off my list, so I am coming here for advice.  I've been scouring the web for a quite a while and have had a number of pages bookmarked for when I finally decided to do this, but information seems to be very thin for this type of project.  A number of people on these forums have talked about wanting to do one, but to the best of my knowledge, no one has.
Heres one example someone did: http://pervivere.blogspot.com/2005/09/holly-shelf-unit-batman.html
and heres another that used to have a lot of great info, but seems of gone down recently: http://www.garymkatz.com/Charts/pivot-bookcase.htm
The problem with both of those is that they both created large bookcases with a door in the middle, but all I have room for is a door turned into a bookcase.  I'm planning on doing something similar to what www.hideadoor.com does.
Pretty much all I have determined so far is that the best hinge for the job is the Soss Invisible hinge, of which the very large 3lb 220 Soss hinge is probably my best bet.  I need a hinge that can hold a lot of weight and still open and close easily, and from what I've read, the Soss hinge is the way to go.  The large one also will give 1/2'' of clearance when the door is open, which is a good thing since the door will be swinging forward and should be able to completely open with the 1/2'' clearance.
For the design I am going to do something similar to this:
although I'm going to curve some of the molding on the top so that it doesn't have such a rectangular shape and is not so obviously a door.
I'm planning on putting the door on a large under the stairs walk-in closet that is just a few steps in from the front door.  Since there is another coat closet right next to it, I'm hoping it won't be too obvious.  I would of liked to hide the downstairs bathroom door, but the floor plan makes it pretty obvious the bathroom is there.  I don't know, maybe I will put it in front of the bathroom, I'll ask some friends what they think and decide later.
Here is the door to the closet, you can also see the other coat closet in the back and the staircase railing in the front.  To the left of the coat closet is the front door, and to the right is the downstairs bath.
« Last Edit: March 13, 2007, 01:53:08 pm by AtomSmasher »
AtomSmasher
    • Atomic-Train
Re: Hidden Door Bookcase - New Project
« Reply #1 on: March 10, 2007, 10:16:56 pm »
I'm thinking of making the inside piece of the bookcase (where the hinges will be attached) out of 2'' plywood, or more specifically 2 1'' plywood boards glued/screwed together, and then the rest of the exterior with 1'' plywood and the board across the center (where the top of the lower cabinet is) also 1'' plywood.  2'' is needed for that hinge, and I figure it will probably be needed to keep the door from sagging anyways.  I don't know too much about building something like this, so please correct me if I am going overkill.  I will then have the three bookshelves 1/2'' plywood and they will also be permantly attached, which will give more support.  I will then make the back piece out of one 1/4'' plywood piece.
I'm sure I forgot something, but I've written so much I doubt anyone will read all it anyways  :P  If you did read it, let me know what you think and any ideas you have.   Thanks.
AtomSmasher
    • Atomic-Train
« Reply #2 on: March 10, 2007, 10:19:02 pm »
Oh, one more thing.  I will probably be ordering the hinges next week and after I receive them, I will do some experimenting and tests to see exactly how to make this thing.  Maybe even make a carboard mockup just to be safe.
ScottS
  • Last login:November 01, 2007, 02:21:30 pm
« Reply #3 on: March 11, 2007, 03:45:00 am »
If you think you're going to make something like this work without casters... I'd think again. Hanging a couple of hundred pounds (or more) off a single 2x4 or 2x6 stud seems like a recipe for disaster; even if the hinges will support the weight, the stud may distort! Ideally you'd want some sort of ball caster that didn't need to rotate as the door was open and closed. Check out page 1287 of the on-line McMaster-Carr catalog for an example. The small one, unfortunately, is a cheesy piece of plastic; completely over-priced for what you get.
The alternative to having a caster on one side of the shelf is to have the door pivot around a central rod. You may need to make steel brackets that support the shelves and attach to the rod. I know I've seen this done somewhere... might have been Monster House.
If you just want a concealed door, there are probably easier ways to do it than building a complete, heavy bookcase.
SavannahLion
« Reply #4 on: March 11, 2007, 07:11:34 am »
You're right about the need for the castors, but the annoying thing about the castors it that over time, the castor creates a groove or mars the floor where it rolls. As far as I've seen, nothing short of putting in new flooring every so often stops the castor from doing this. In one such setup, the castor even bit into concrete flooring.  :( Not a good way to hide a door if they can see the castor marks.
I'd offer a solution of my own, short of opening the door IN instead of OUT, all of the ones I can think of involve more work than the easiest design. :dunno
  • Last login:Yesterday at 01:37:20 pm
« Reply #5 on: March 11, 2007, 08:22:46 am »
Wow cool!  I've always been intrugued by hidden doors too...
  • Last login:February 04, 2026, 05:27:25 pm
« Reply #6 on: March 11, 2007, 11:31:35 am »
Seems like some high quality rubber casters would protect your floor decent enough.
« Reply #7 on: March 11, 2007, 11:33:54 am »
You could create a book case that breaks in half and opens in the middle. This would allow you to split the weight load.
If I were doing this - I would keep the door on there and build the bookshelf on the door and keep the door as a base (or on a replacement door).
NiteWalker
  • Last login:April 25, 2022, 07:33:24 pm
  • Routers can do anything.
    • SimpleCase Custom Arcade Stick Enclosures
« Reply #8 on: March 11, 2007, 11:45:22 am »
These are excellent casters that are solidly built and made of a polyurethane rubber that won't mar floor panels. They're great.
It's 9am. I'm calling it a nite.
AtomSmasher
    • Atomic-Train
« Reply #9 on: March 11, 2007, 01:10:41 pm »
I've been considering a castors, but I really want to avoid using them.  I don't plan on filling it with books, so the wood itself will be the heaviest part.  I realize I will probably have to reinforce the stud if I don't use castors, anyone know of the best way to do this?  The easiest way would be to add another 2x6 to it and have a beam across the top and the bottom to help hold it in place, but I don't know how strong that would actually be.  I suppose I could just put in a 4x4 beam to install the door onto.
I've considered doing a center pivot system (as ScottS mentioned) and would actually use a Rixson Center Hung Pivot instead of an actual rod.  The problem is the door is small enough that putting a center hinge would leave only about 18-19'' of doorway width to walk through.  The only way I could do that is if I built a large bookcase in front of the door, which is another possibility if everyone thinks theres no easy way to reinforce the stud.
AtomSmasher
    • Atomic-Train
« Reply #10 on: March 11, 2007, 01:15:38 pm »
I searched the wayback machine for the earlier link I posted that is now dead, and luckily they still have it with all of the pictures.
http://web.archive.org/web/20060427025850/http://www.garymkatz.com/Charts/pivot-bookcase.htm
If I made the bookcase in front of the door, I would make it like this, except I would only have room for the center bookcase, not the two side ones.
NiteWalker
« Reply #11 on: March 11, 2007, 01:37:29 pm »
Once you reinforce the studs, the stress will then fall on the hinges themselves. I know the ones you linked to are rated for 500lbs, but you also have to take into account the stress on their mounting method. Regular screws probably won't do. I'd go for long lag screws or even carriage bolts. The problem with carriage bolts would be accessing both sides of the studs to attach them. You'd have to wait to finish the wall until the bookcase door was already installed.
Back to the casters, you'd really only need one at the edge closest to where the door opens. It's possible to make it hidden as well.
« Reply #12 on: March 11, 2007, 03:11:29 pm »
Sounds perfect to me
AtomSmasher
    • Atomic-Train
« Reply #13 on: March 11, 2007, 04:07:33 pm »
Heh, well its a closet and I still want to keep it functional, so I'd rather keep the door as wide as possible.
Quote from: NiteWalker
link=topic=64170.msg641170#msg641170 date=1173634649
I believe both hinges I linked to come with screws made to be able to withstand a large amount of weight, so I don't think that will be a problem.  If I did have to access the back of the stud, then I would just cut out the drywall on the inside of the closet so it wouldn't be noticable.  Drywall is repaired easily enough so I don't think it would be a problem.
I've thought a lot about casters, and I know I would only need one and that it can be hidden, but it would be traveling over carpet so it would make an extremely noticable mark and would make opening the door much rougher.  Theres a number of online stores that sell these same type of bookcases (http://hiddendoors.com & www.hideadoor.com to name a couple), and none of them have casters, so I know its possible to do it without one.  If I went with the center hung pivot, then I know I wouldn't need one since the author of the web page I posted (Gary Katz) has mentioned in a number of other forums how great those hinges have worked for him on multiple bookcase projects.  Maybe it would be best to use 4 hinges instead of two if I went with the Soss hinges.  It would be an extreme overkill, but it would definately hold, assuming the stud was properly reinforced enough.
edit* I was thinking that if I went with 4 hinges, then it would be over 12 lbs of just hinges, a bit of an overkill.  Maybe I should go with the slightly smaller 218 Soss hinge instead.
edit of the edit* after doing a little more searching on the Soss hinge, I found their manual: http://www.soss.com/pdf/SossCatalog2006.pdf
it seems www.hiddendoors.com uses their hinges and that a 250lb door would need either 4 218 hinges or 3 220 hinges.  When buying the hinges, they come in sets of two, so if I went with the 220 hinges, then I would use all four making it strong enough to hold at least 300lbs.
« Last Edit: March 11, 2007, 04:48:17 pm by AtomSmasher »
SithMaster
« Reply #14 on: March 11, 2007, 08:43:42 pm »
What about having the door push into the room and then split to the left and right?
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #15 on: March 11, 2007, 08:55:38 pm »
This is AWESOME.  My wife and I just put money down on a lot so we can build a custom house on it.  I've been thinking of adding a small hidden room in the office all day, bookcase door of course.  It's a requirement for the new house.  It's nice to see you guys think the same way.
Even better, the door enters a small shaft with a ladder and put the secret room on the second floor (or basement).  Oh, that would be cool.
Next I'll be on fries, and that's when the big money starts rolling in.
Nannuu
« Reply #16 on: March 11, 2007, 08:58:16 pm »
Where can you add a picture frame that you can see out of from the room?
Private Eyes, one of my favs.
NiteWalker
« Reply #17 on: March 11, 2007, 09:35:12 pm »
Maybe even one of those one sided mirrors.  >:D
AtomSmasher
    • Atomic-Train
« Reply #18 on: March 11, 2007, 09:51:19 pm »
lol, that would cut the wieght for the whole thing down.
paigeoliver
  • Awesome face!
« Reply #19 on: March 11, 2007, 11:02:14 pm »
Strangely enough a secret door has been on my list of things I have wanted for a long time too. I would prefer to have a whole room back there though. A closet just sort of cheapens the whole thing. Although my apartment DOES have a closet that intuitively shouldn't exist. The whole apartment is one giant rectangle except for this one closet that leads outside of that space.
NiteWalker
« Reply #20 on: March 11, 2007, 11:09:36 pm »
A hidden room behind a bookcase door would be awesome.
To the batcave! :applaud: :cheers: ;D :dunno
AtomSmasher
    • Atomic-Train
« Reply #21 on: March 12, 2007, 01:13:40 am »
Ya, I agree I would prefer to have a whole room behind the door, but theres not really any room that looks like their shouldn't be a door there.  Especially since I want to have the door downstairs so people actually see it and hopefully don't notice it  ;D
Heres a link to my floorplan if your curious:  http://www.atomic-train.com/images/My%20House/floorplan.gif
If all goes well, I may build a second one for one of the rooms upstairs.
Now, back to actually building it.  What do you think will be necessary to reinforce the stud?  I think I will go with 4 of the 220 hinge (the biggest one) just to be on the safe side, so reinforcing the stud is my main concern.  I'm thinking one 2x6 along the side and one along the top (the top one jammed against the side one to keep it from coming out) would probably be enough extra support. What do you think?
DrewKaree
  • HAH! Nice one!
    • A lifelong project
« Reply #22 on: March 12, 2007, 03:11:44 am »
I know there's a mag I have or looked at that had this.  I'll see if I can figure out if I have it or what it was.  If I have it, I'll scan it for ya.
If'n you wanna help, look to see if Fine Homebuilding, Family Handyman, or some other mag along that order has anything within the last few months....mebbe back to November at the earliest, if I can remember.
AtomSmasher
    • Atomic-Train
« Reply #23 on: March 12, 2007, 03:41:37 am »
A little googling and I found that it was issue 184, Taunton's, Fine Homebuilding (Dec 06/Jan 07) that had the article your talking about.  Unfortunately I haven't found any scans of the article, so it would be great if you could find your copy of it.  I may just try to order a back copy of it if you can't.
Heres a preview of the it: http://www.taunton.com/finehomebuilding/pages/fh_184_066.asp
Thanks for the heads up on the article DK.
DrewKaree
  • HAH! Nice one!
« Reply #24 on: March 12, 2007, 04:04:23 am »
I thought it was a bit farther back than that, actually, but there's a very good chance I have it lying about somewhere.  The wife cleaned up Friday, so now I've gotta get my "system" of craporganization back and working again.  I'll give it a looksee tomorrow after I wake up.
menace
« Reply #25 on: March 12, 2007, 09:10:09 am »
I have the articled scanned--where can I send a 2mb pdf?  Just be prepared its pretty skimpy on details--think more like "if you have already built one, how does it compare to ours?"  Again I'm amazed on the confluence of hobbies on this board...I have my hidden door spot already picked out  :cheers:
AtomSmasher
    • Atomic-Train
« Reply #26 on: March 12, 2007, 09:43:50 am »
Awesome, thanks.  If people want, I can host the files on my webs server for a while.
GadgetGeek
  • Last login:July 09, 2024, 09:32:57 am
  • whatever
« Reply #27 on: March 12, 2007, 12:47:06 pm »
There was recently a show on HGTV called Secret Spaces or something like that.  It had houses full of stuff like this.  If you can find a copy of it, it is worth watching, especially if you want a ton more ideas stuck into your head.
DrewKaree
  • HAH! Nice one!
« Reply #28 on: March 12, 2007, 06:17:38 pm »
That's what you pulled out of that article? :dizzy:
Seemed far more like a "if you're planning on doing this, here's some tips and planning steps to keep in mind and try to incorporate into your design for better operation"
Are you sure we're talking about the same article?  pp66-69, Fine Homebuilding, January 2007, no. 184  Guy finishing a wood floor on the cover?
AtomSmasher
    • Atomic-Train
« Reply #29 on: March 12, 2007, 06:32:01 pm »
Thats the one he sent me.  I just got around to reading it and while its not as detailed as I hoped, it does still give quite a bit of good info.  One of the main things I got out of it is that I should use 3/4'' plywood for the backing in order to keep it from sagging.  I figured smaller wood would be enough (as did the author since his first door was a failure), but now I know otherwise.  He also mentioned that a bookcase door full of books generally weighs around 250lbs, which means I should be fine with the hinges I choose (4 of the 220 Soss hinges should hold at least 300lbs).  He used a ball bearing hinge, but he also had the door swing in, so there was no need to hide the hinge.
He also used surprising small amount of reinforcement for the hinge attached to the wall.  It makes me think that I will be able to add enough reinforcement to the stud by just adding 1'' thick plywood along the side and one along the top of the door jam to make sure it doesn't come loose.
AtomSmasher
    • Atomic-Train
« Reply #30 on: March 12, 2007, 08:07:45 pm »
Well I just bought a pair of 220 Soss hinges from ebay for $45 shipped, which seems like a real good deal.  I'll still need to find another pair, but at least now I can start experimenting with them.
« Reply #31 on: March 12, 2007, 11:51:51 pm »
I got an idea.
Build a mame machine to put in the closet and put all those adult games on that arcade.
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #32 on: March 14, 2007, 09:38:26 pm »
How about a piano hinge running up the side of the bookcase that would be hidden by the molding.
You also want to check the framing around the door for a double upright stud on both sides of the door and at least 2 x 4 header, a 2 x 6 would be better with the weight.
I look forward to updates and progress pics.
Cheers
There are three kinds of people in the world those that can count and those that can't.
ScottS
« Reply #33 on: March 15, 2007, 02:25:03 pm »
If you've got a source for a 6-7' piano hinge that will support 250+ pounds when mounted vertically, I'd love to hear about it!
modessitt
  • Last login:October 17, 2021, 07:02:28 pm
  • Technician
« Reply #34 on: March 15, 2007, 10:38:50 pm »
I like the idea and hope to see some good photos of your progress.  Just remember, a hidden room does no good if you're asking your friends for advice on building it.  They'll know where it is!
Too bad you don't have more wall space near the door.  Then you could just build it as a sliding bookcase, either outside "against" the wall or built into it.  Against the wall could slide on tracks hidding behind the bookcase in a method similar to how van side doors open.  In the wall would slide like patio doors, with the sliding hardware mounted inside your hidden room and and the front of the shelves sliding behind the wall and the left and right edges hidden behind molding, making it even harder to detect.
Of course, it would be a simple task to rig the old "pull a certain book to release the latch" trick with that kind of system.
I remember seeing a show sometime recently where they were discussing "panic rooms" and had a bookshelf that opened inward as a less obvious door located near a more obvious false door.  They reinforced the framework near the door with steel and armored the door.
I like the idea of the entrance to the room being on a separate floor than the actual room, although a "bolt-hole" would be necessary for emergencies.  Probably a crawlspace tunnel either outside or to another part of the house.
Now all you have to find is a talking picture to ask for your password in a British accent....
Working Games:Joust CT,Gyruss UR,Pong,Battlezone UR#1
Current Proj's:Battlezone UR#2
Cheap/Free Cabs Wanted: DK,KarateChamp,Shinobi,Ghosts&Goblins,CircusCharlie,10ydFight,PolePositnCP,RallyX,Frogger
modessitt
  • Technician
« Reply #35 on: March 15, 2007, 11:18:07 pm »
Just checked out the site your first picture came from and noticed something I missed earlier...
There is a space at the bottom of the "bookcase", just like a door has, for air flow.  This could be a huge tip-off to an observant visitor who may wonder why there would be space under a bookcase mounted into the wall.  A solution to this problem would be to replace the baseboard along that wall to continue straight across like the wall is one-piece, matching the original baseboard in style and color.  Mount it so it sits flush against the front of the "bookcase".
This would look more authentic and help keep your hidden room "hidden".  The only drawback would be that you would have to step over it when you enter the room.  Of course this assumes that your door swings inward.  If it doesn't, you'll either have space under the door, or breaks in the baseboard along the edges, another tip-off.  And if it opens outward with a case that reaches the floor, you risk leaving trackmarks on the floor (or carpet) that will show after repeated use.
Sorry if I'm pointing out things only a potential thief would notice.  Must be my sneaky nature....
AtomSmasher
    • Atomic-Train
« Reply #36 on: March 16, 2007, 03:12:51 am »
I have thought about that and since my door will be swining outward it will be a little tricky.  What I'm thinking of doing is put a few inches for boards attached to the floor, then I will have the door hang over it a little bit, but still be high enough so that the board attached to the floor is easily seen.  My hope is that it will just look like a slightly recessed section at the bottom which is pretty common in cabinets (its even in the arcade cabinets I built).
I doubt my carpentry skills are good enough to make this thing impossible to detect, but I'll do what I can.  I'm not doing this to have a safe room or anything, just something cool to have  ;D
shardian
« Reply #37 on: March 16, 2007, 09:37:05 am »
First off, you weren't an odd kid. Every single one of us had the same dreams...that is why we are all here. ;D However, it is disappointing that dating a supermodel wasn't on your list. :laugh2:
Now my two cents:
You will be using hinges rated for 300 lbs, you won't need a "roller" support for the few minutes the door will be open. Your main worry will be what is supporting the other side while the door just  sits there closed. A better support solution would be to integrate a support into the framing on the other side that the bookcase rests on while the door is closed.
Also, you better dag gone well make it so that a certain book pulled out partially disengages the latch mechanism. Otherwise, you are wasting your time. ;D
4Aaron GE
  • Last login:July 22, 2013, 10:27:07 pm
« Reply #38 on: March 16, 2007, 11:01:13 am »
I disagree.  A bust of Shakespeare would be equally as good for the purpose.  Bonus points if it's this one:
http://photos1.blogger.com/blogger/1523/433/1600/batman.jpg
myntik1
  • Last login:April 26, 2021, 12:03:28 pm
  • I'm part Jerry Lee and part Jerry Lee Lewis
« Reply #39 on: March 18, 2007, 08:03:57 pm »
We;re looking for a new house and I just looked over at the missus and sad the new house has to have a spot for a bookcase/hidden doorway.  She gave me the same look (like I'm having a cranial misfire and she just wants to humor me) that I got when I got said I was building a juke. I guess I'll have to secretly build it in the garage like everything else and then when she sees that it's not hideous I can bring it inside.
And am I the only one who wanted to be a professional wrestler as well?
full-time sucker for part-time pay
