Author Topic: Double Image on Billabs Monitor  (Read 2078 times)
Man_Utd
  • Last login:July 22, 2011, 11:37:12 pm
« on: March 21, 2011, 01:20:43 am »
I have a Billabs BL25C90T, and I'm having trouble displaying 640 x 480 @ 60Hz.  I'm getting two images.
I'm using Soft-15kHz, a j-pac, and a Nvidia 6600 (Gigabyte NX66256DP).  I've played around with the controls on the monitor but haven't been able to fix it.  Any help would be appreciated.
BobA
  • What Me Worry?
Re: Double Image on Billabs Monitor
« Reply #1 on: March 21, 2011, 09:11:52 am »
Looks like your jpac is not getting a 15 Khz signal so it is halving the signal.
"If required, can divide a 31Khz VGA signal in half so that it will display a stable picture on a 15Khz arcade monitor. Useful for checking boot-up progress and configuration (not for application use). Automatically stops dividing the signal when it detects a correct 15Khz rate is being send by the PC."
Probably something not setup correctly in soft15 or the card to give you a 15Khz signal.  Sorry no experience with soft15.
Man_Utd
« Reply #2 on: March 24, 2011, 10:46:35 pm »
Thanks for posting BobA.  I solved my problem by looking through the boards and came across this post http://forum.arcadecontrols.com/index.php?topic=110302.0.  I removed the jpac and connected the video card directly to the monitor and it worked.
I wanted to use the jpac to block the high resolution signals from damaging the monitor.  Oh well.
