Author Topic: J-PAC split screen  (Read 2669 times)
clutch
  • Last login:February 06, 2014, 02:26:56 pm
J-PAC split screen
« on: March 10, 2011, 08:29:49 pm »
I searched for a solution but came up empty.
NVIDIA onboard graphics hooked to JPAC.  I've jumpered 15 and 31 because my Nanao 2933 multisync if fully capable of autoswitching.  However, I get a split screen on everything (like the screen starts in the middle and overflows to the right then continues on the left).  If I only put a jumper on 31, everything works fine.  Same for 15, everything works fine.  I want to jumper both so I can run pac-man at 15 and the newer games at 31.  Am I missing something here?
clutch
Re: J-PAC split screen
« Reply #1 on: March 15, 2011, 11:21:03 am »
I was told by Andy that the JPAC was intended for single resolution monitors and that if you have a multi-switching monitor, use the vga cable.
