Author Topic: Pentranic 1025 help  (Read 1855 times)
skinnyd77
  • Newbie
  • Last login:July 07, 2012, 07:50:20 pm
Pentranic 1025 help
« on: February 27, 2011, 10:57:06 pm »
Hi,
I've got a Pentranic 1025 (25") inside of a mame cabinet I'm building.  I using an ArcadeVga card as a video interface.  The monitor is almost identical to this one: http://www.jomac.net.au/Pentranic_Rodotron_CH288.jpg
Here's what happened:
Once I finally had all the wiring in and everything setup inside the cab, I powered on the monitor and PC.  The boot-up screens and Windows welcome screen came up fine, but the image was flipping.  When I started to turn the V-hold knob on the remote adjustment board, the image immediately shrank to a single line running left to right across the middle of the monitor.  There MAY have been a puff of smoke, but I did not see any, just kind of a metallic smell from the back when I powered everything off.
From hours of googling, I found that I could have any number of problems.  This website http://www.repairfaq.org/samnew/tvfaq.htm was surprisingly informative, but put me no nearer to a solution.
The other thing I should probably mention is that I am scared to death of poking around the monitor components, nor are my soldering skills up to par for a task like this (I think).
My best guess is that the knob that controls v-hold is toast, but I haven't a clue how to fix that.
I'm contacting the arcade where I bought the cabinet in the morning, but if it's something I can attempt to fix myself rather than pay someone, that would be obviously a lot better.  There are 1 or 2 local repair places that I can call, but any help or opinions are greatly appreciated.
Thanks in advance
David
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
Re: Pentranic 1025 help
« Reply #1 on: February 28, 2011, 08:02:16 am »
Because you mention it is model 1019, I do not think it is a CH288. the first 2 numbers in the Pentranic scheme being 10 would normaly indicate that it requiers an isolation transformer. Check aroud the board for silk screening of the chassis #. If it is a true CH288, you will find that number on the circuit board by the flyback.
If so replace C318 a small Tantalum capacitor, if it gets out of tolerance it can cause all kinds of issues.
Good luck!
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Rickn
« Reply #2 on: February 28, 2011, 08:04:16 am »
Sorry, meant to say model 1025, not 1019, but same still applies.
Rick Nieman
519-621-1722
