Author Topic: Help Finishing front end.,..  (Read 2272 times)
bcgamer
  • Last login:September 30, 2021, 02:33:37 pm
« on: February 20, 2011, 10:22:13 am »
hi guys
    Finally flew back into town and want to finish my mame cab.  Its sat for about 6 months while i was out of province working.
   I have Mame Rom Set 0.138 and the extras from the boys from [romsite name redacted].  Is there a new release of rom set out there I should update to?
   I also want to use Maximus Arcade for a font end but am having troubles properly setting up my tankstick.....is their a praticular driver that I should replace the stock one with?  I reaaaallly want to hasve this system running clean with no problems so if anyone has any ideas/suggestions that would be awesome....I will be working on this thing asll day today.
« Last Edit: February 05, 2015, 01:47:40 am by PL1 »
bcgamer
Re: Help Finishing front end.,..
« Reply #1 on: February 20, 2011, 10:26:28 am »
i noticed mame rom sets are now up to 0.141.....is this a stable release?
sooo many little things to get caught up on....any help would be great
thanks guys love this site
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
« Reply #2 on: February 20, 2011, 12:14:47 pm »
The general consensus seems to be that you shouldn't feel obligated to update your romset every time there is another version release.
Keep an eye on the changelogs, and see if the new versions offer any new features or games that you'd really want to play that you couldn't before.
They seem to change so frequently, it's hard to keep up.
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #3 on: February 20, 2011, 09:07:56 pm »
I'm pretty sure that even mentioning where to get ROM's is against the rules of this site. I'd suggest removing the torrent site from your original post.
For the most part I try to keep my MAME set updated at set at every major release.  IE: 141, 142, 143, etc..  I will sometimes update a an update release (IE, 141u2) if there is a game that was added between 141 and 141u2 that I want to play.
This is what I do:
1. compile new version of MAME
2. download update (140 to 141) ROMset
3. merge/rebuild into existing ROMset
4. audit newly merged set
5. connect to full torrent to share.
I also, keep the update (140 to 141) set seeded to help build ratio.
kaptainsteve
  • Last login:February 18, 2024, 01:30:53 pm
    • Swamp-Ass
« Reply #4 on: February 26, 2011, 05:23:16 pm »
My advice, stay away from 141.  I've had nothing but compatibly problems between it, all the frontends I"ve tried it with, and my video drivers.... it crashes upon exiting games.
In fact, that leads me to wanting to roll back to an earlier version,  which version do you think is the best version (least amount of problems, uses least resources, least compatibility problems) to roll back to?
« Last Edit: February 26, 2011, 05:26:41 pm by kaptainsteve »
Dazz
  • HyperSpin Team
    • VPUniverse
« Reply #5 on: February 26, 2011, 07:17:51 pm »
What are you doing wrong?  What version of 141 are you using? 64? UI? 32?  Are you using a version that you compiled yourself or downloaded?  You've bitched and bitched about 141 several times, yet you haven't given any real details.  I've been running 141, since they released the source, without any issues in both HyperSpin and Maximus Arcade.
I just read your edit on you other post in the FE thread.  Your issue isn't a MAME 141 issue....  The issues that you are describing have nothing to do with MAME at all.  This is definitely an issue with either your OS environment or even your hardware.  What keyboard encoder are you using? IPAC?
« Last Edit: February 26, 2011, 07:23:09 pm by Dazz »
kaptainsteve
    • Swamp-Ass
« Reply #6 on: March 07, 2011, 06:50:08 pm »
Dazz,
Do you want to know what YOU are doing wrong?
I'll tell you.  You should learn to talk to people the same way over the 'net as you would in person.
Kaptainsteve
nickynooch
  • Last login:August 29, 2020, 02:54:00 am
« Reply #7 on: March 08, 2011, 04:34:35 pm »
« Last Edit: August 29, 2020, 02:44:07 am by nickynooch »
kaptainsteve
    • Swamp-Ass
« Reply #8 on: March 10, 2011, 04:10:05 pm »
Try installing MameWah, which is a nice basic FE.  It's easy to install and has a nice easy menu for a cabinet.   I had some problems with other FE's (as Dazz points out), but MameWah cleaned things up for me nice.
