Author Topic: Neotec 2515C Vertical collapse  (Read 2925 times)
Q*Bert_OP
  • Oh yes, we did!
« on: February 09, 2011, 10:33:06 pm »
I have a Neotec 2515CGA that's shrunken to a thin horizontal line. The vertical deflection IC (IC301) has been changed, that wasn't the problem. I have also changed C307 & C308.
The IC I installed was an NTE1855. I couldn't find an LA7835 at any of my usual suppliers.
The V HOLD pot is good, as well as the wiring between the chassis and remote board.
The picture turned from being clear and sharp to looking like a watercolor painting. I turned the game off, then back on, and was greeted with a thin horizontal line.
What next?
lilshawn
  • Last login:March 16, 2026, 03:44:11 pm
Re: Neotec 2515C Vertical collapse
« Reply #1 on: February 10, 2011, 12:53:08 am »
the original chip spec'd in the maunal for IC301 is an LA7836 not an LA7835
the NTE cross is an NTE7085 not an NTE 1855
%20[English].pdf]http://pdf.textfiles.com/manuals/ARCADE/K-R/Neotec%20NT-2515C%20NT-25E%2025in%20EGA-CGA%20Color%20Monitor%20[Service]%20[English].pdf
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: February 10, 2011, 12:57:51 am »
I know that, but the 7835 is what was on the monitor when I took it apart. It had never been serviced before.  Besides, no tech EVER re-installs the 2 screws close to the front of the tube  :cheers:
lilshawn
« Reply #3 on: February 10, 2011, 01:03:23 am »
I hear that!  :cheers:
IC401?
it's tied to the vertical... it's where the timing signals for ic301 come from. i usually replace 401 first, then 301 if it's still flat lining.
