Author Topic: AdvanceMESS Help  (Read 1775 times)
bball
  • Last login:February 20, 2005, 12:54:37 am
AdvanceMESS Help
« on: August 21, 2003, 03:09:27 pm »
I'm trying to get AdvanceMESS to work on a WG-D9200.  I am running Win98 and I have downloaded bot the DOS and Win32 versions of regular MESS and have gottne both to run just fine.  I then tried to use AdvanceMESS but the screen just goes black.  I see the "OK" nag screen come up (just like AdvanceMAME) but after I get past that screen it just turns black and I have to hit ESC to exit.  For the advmess.rc file I just copied the video device entires from my advmame.rc file (I know those work fine for Advance MAME).  Any ideas ?
BTW: I'm trying to play the Genesis game Streets of Rage 2 :-)
bball
Superdude
  • Last login:January 22, 2016, 11:53:48 am
  • Mo' Betta Butter with da Betta Playa'
Re:AdvanceMESS Help
« Reply #1 on: August 21, 2003, 07:04:52 pm »
Mess is a Mess, lots of games are not supported.  Your better off using a specific emulator.
GENS works great.
bball
Re:AdvanceMESS Help
« Reply #2 on: August 28, 2003, 06:59:00 pm »
But the reason I wanted to use AdvanceMESS is because I wanted it to output the Genesis video at 320x224 (?) 60HZ.  I have tried some IRC channels and have also e-mailed the AdvanceMAME mailing list with no luck :(
I'm beginning to wonder if AdvanceMESS even works or if anyone has actually ever used it :)  I have yet to find anyone that uses it.
bball
jakejake28
  • Last login:September 02, 2005, 07:23:54 pm
  • Thank you sir, may I have another?
Re:AdvanceMESS Help
« Reply #3 on: August 30, 2003, 04:36:56 pm »
bball
yea, people have used it...
but using each individual emu has so many more advantages... like compadibility with more than 10 games per system
It's all about the Pentiums
bball
Re:AdvanceMESS Help
« Reply #4 on: August 31, 2003, 06:43:00 pm »
But are there any console emulators that can will output the video for a standard res arcade monitor ?
bball
jakejake28
Re:AdvanceMESS Help
« Reply #5 on: August 31, 2003, 06:50:12 pm »
via what? i remember there was a gensAVGA for arcade vga... i dont know where you can get it, cause wonderboys site was down last i checked...
heres the thread
http://www.arcadecontrols.org/yabbse/index.php?board=3;action=display;threadid=7192;start=msg70988#msg70988
« Last Edit: August 31, 2003, 06:53:59 pm by jakejake28 »
bball
Re:AdvanceMESS Help
« Reply #6 on: August 31, 2003, 08:00:31 pm »
I have a trident blade T64 video card.
bball
