Author Topic: Cutting an LCD monitor casing  (Read 2261 times)
mike boss
« on: January 15, 2011, 09:32:00 am »
Picked up a replacement monitor for my "bartop keeper project" aka Mini-Kong.
Monitor is great, looks good, works good, etc. Problem is it's TOO BIG!
I de-cased the monitor trying to find a mounting solution and was left with none.
The electronics (if that is what it is/you would call it) are covered by a metal housing, then you have the screen.
But the electronics and the screen itself are not joined in any way. The screen sits in the housing (case) nice & snug,
and the electronics are mounted with 4 screws. Long and short of it I think the best solution is to cut down the LCD
monitor case. Purchased as is no warranty exists anyway (for what its worth).
I'm not a very handy guy, and I'll end up having to get someone to help me.
I'd like to get as smooth a cut as I can, any type of saw someone could suggest ?
For some reason I see a jigsaw just going berzerk on this, perhaps a dremel type tool  ?
BobA
  • What Me Worry?
Re: Cutting an LCD monitor casing
« Reply #1 on: January 16, 2011, 01:11:42 pm »
I had to cut some parts off of an LCD monitor case for a recent build.  I used a cutting wheel on a dremel with the case taken apart to trim where I needed.  A jigsaw was not an option as there is too much movement to control a clean cut.
mike boss
« Reply #2 on: January 16, 2011, 04:34:33 pm »
Sweet, that is what I had thought.
But wanted a second,third,fourth,even fifth opinion.
Now to get a dremel!
