Author Topic: s-video out from 6800gs only black and white  (Read 1938 times)
isometrik
  • Last login:October 18, 2010, 12:51:57 pm
« on: October 14, 2010, 11:12:58 pm »
Just tried hooking up my 27" sony trinitron to the s-video out from my pc only to find the picture in black and white only. The picture comes in fairly clear, but without any color even in the bios. When I hook up a pc monitor via dvi or vga the color is there. I tried messing around with different drivers, even uninstalled the drivers to no avail. I also messed around within the nvidia control panel to change from s-video to composite but it didn't change anything.
The card doesn't have a tv output, just the standard 4 pin s-video. I tried two different cables, but both produce the same result.
Anyone else come across this issue? Any ideas?
Blanka
Re: s-video out from 6800gs only black and white
« Reply #1 on: October 15, 2010, 02:14:54 am »
If your TV display's b and w, then the TV is not at the right input with the AV select button. I have a sony TV too, and I know Svid is sometimes B&W, because it is on the composite version of the selected input (I see both Input 1 Y/C AND Input 1 C while toggling inputs.
Are you perhaps using a Svid-SCART adapter?
« Last Edit: October 15, 2010, 02:16:29 am by Blanka »
Frigo
  • Last login:December 09, 2011, 04:23:54 pm
  • My spoon is too big.
« Reply #2 on: October 15, 2010, 10:05:10 am »
Could also be that your Chroma pin is loose on the card. The luma pin carries the sync signal and luminance, so that side comes through as b&w. the chroma carries color, so if you've used two different cables, you might want to take a look at the card.
isometrik
« Reply #3 on: October 15, 2010, 11:09:03 am »
I tried switching video inputs on the tv, but the only one where anything showed up was video 1, in black and white. I also inspected the cable and the two ports, all of which seemed to be clean with no bent pins or anything. Should I just bite the bullet and buy a new graphics card?
Frigo
« Reply #4 on: October 15, 2010, 12:00:38 pm »
If you have another TV, I'd try that, first.
gazz292
  • Last login:January 22, 2022, 12:00:01 pm
« Reply #5 on: October 15, 2010, 04:32:55 pm »
your TV is in the wrong mode, it's expecting a composite signal which has the colour and luminance signals on the one wire, but s-vid has them on seperate wires,
somewhere in the menu's should be a setting to tell it to accept s-video, i assume your using the main scart connector?? as they can take rgb, composite and s-video, but use the same pin for composite and one of the s-vid's signals, so unless it's told to work in s-video mode, it displays black and white on s-video input.
being a sony trinitron it shoudent be lime the old tv i had, which only had rgb and composite inputs on the scart, no way to feed it s-video via the scart with any adaptors (exept thos which combined s-bid to composite with the loss of quality associated with comosite)
If your using a dedicated s-video port on the tv, it should have it's own AV number, i.e. AV2 or 3, but it could be possible the s-video port it just piggy backed to the scart socket internaly, so you wtill need to tell the tv it's being fed a s-video input to get the colour signal in.
