Author Topic: Monitor buzz WG D9200  (Read 1628 times)
cmoses
« on: August 30, 2010, 12:08:01 pm »
I have a Wells Gardner D9200 Monitor running at 640 x 480.  When I boot into windows it has a "buzz" sound coming from the monitor.  When I open up a window, the buzz goes away.  I do not get the buzz when running HyperSpin or MAME, I only get it in windows with no windows open.
Any ideas?  I have tried a few refresh rates, 70, 72, 75 and it does it at all of them.  I have a Nvidia 9400GT 1MB card in the machine.  Is there a specific driver I should be using for that monitor?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Monitor buzz WG D9200
« Reply #1 on: August 30, 2010, 04:23:42 pm »
move it away from the window  ;D
under varying loads, a smps can produce audiable noise .
max crt beam current will be on an all white screen ( high load )
opening the 'puter window changes that beam current.
if this monitor has substantial service time , there may be caps that should be replaced...
