Author Topic: TV Display Issue  (Read 2398 times)
Xynie
  • Last login:July 13, 2020, 09:30:19 am
  • Sometimes, I feel like Dilbert.
TV Display Issue
« on: August 21, 2010, 05:42:23 pm »
Hey all.. I need a little assistance.  My cabinet is about complete, but I am running into a problem outputting video.  I have a PC running XP-64 outputting from an HD4350 with S-Video to a Sony Trinitron 27" Tube TV.  It works fine hooked up to a computer monitor, but when I boot via SVideo to the TV it gets as far as the bios then first XP screens, but once it tries to load the login screen the TV goes black.  I assume it is out of range somehow, but I think the ATI software is creating multiple profiles.  When the monitor is plugged in I am running 640x480 at 60 refresh rate.... I thought that would be in range of what the TV would handle.
Anyone have any ideas?  Think its a driver issue or settings issue?  I think I need to set a "default" range when a TV is used... My only thought is to uninstall the ATI driver, use standard VGA to get into the PC, then reinstall the driver with the TV hooked up.
Thoughts?
Anthony
Xynie
Re: TV Display Issue
« Reply #1 on: August 21, 2010, 06:25:49 pm »
So I uninstalled the driver, rebooted, and it worked for a bit... but after another reboot stopped working again.  Just an update.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: August 21, 2010, 09:38:20 pm »
basic standard ntsc specs ( color) are
horiz  15.734 khz
vert 59.95 hz  30fps
chroma sub carrier  3.579545 mhz
feed it what it wants, and it will be happy   ;D
