Author Topic: monitor problems  (Read 2096 times)
xrodney
  • Last login:August 31, 2023, 09:57:19 am
monitor problems
« on: August 20, 2010, 11:54:43 am »
Hi
I just got a mortal kombat 1 arcade and after a few minutes the picture gets a bit faded and when switched images, it shows a solid red colour instead of a dark black colour.  what can be the problem? and can it be fixed?
grantspain
Re: monitor problems
« Reply #1 on: August 20, 2010, 05:34:04 pm »
leaky drive transistor or dry solder joint
stillvip187
  • Last login:August 30, 2010, 08:32:02 pm
« Reply #2 on: August 22, 2010, 01:11:40 pm »
Hello everone I have a KI1 that was turned in to a KI2 but am haveing this Monitor Problem after I tryed to ajusted the monitor has anyone out there seen this befor
http://img801.imageshack.us/i/ki2.jpg/
http://img413.imageshack.us/i/img2902h.jpg/
« Last Edit: August 22, 2010, 01:22:44 pm by stillvip187 »
grantspain
« Reply #3 on: August 22, 2010, 03:37:10 pm »
oh nice,partial vertical frame collapse-is that a nanao ms8 monitor?
check for broken vertical size pot and bad solder joints then there is a repair log on arcadeotaku wiki showing you how to fix this
