Author Topic: Windows file management  (Read 1975 times)
shmokes
  • Don't tread on me.
    • Jake Moses
« on: August 13, 2010, 02:21:21 pm »
 :timebomb: :timebomb: :timebomb: :timebomb: :timebomb:
Why when you try to rename or move a file does Windows say: The action can't be completed because the folder or a file in it is open in another program
This is so infuriating and it happens all the bloody time!  Dear Microsoft, here's an idea.  Tell me WHAT PROGRAM IT'S OPEN IN!!!  Cos nothing's running.  And I'm happy to kill a processes for you but I don't know which one is causing you confusion.  But you do.  So why don't you just tell me?
So annoying.
Best Kid iPad Apps
smalltownguy
  • Last login:February 27, 2026, 07:59:15 pm
Re: Windows file management
« Reply #1 on: August 13, 2010, 02:30:57 pm »
www.linux.org
 ;D sorry, couldn't resist *hee hee
gryhnd
« Reply #2 on: August 13, 2010, 02:32:19 pm »
I use this on the occasions that happens:
http://ccollomb.free.fr/unlocker/
Completed: No Name Upright
ahofle
    • Arcade Ambience Project
« Reply #3 on: August 13, 2010, 03:47:03 pm »
Process Monitor (formerly FileMon)
Blanka
« Reply #4 on: August 13, 2010, 04:11:30 pm »
Put all documents on an external FW hard drive. Just unplug/replug if Windows starts bitching. :D
As for linux, UNIX files systems can lock files too  :angry:
« Last Edit: August 13, 2010, 04:13:26 pm by Blanka »
Frigo
  • Last login:December 09, 2011, 04:23:54 pm
  • My spoon is too big.
« Reply #5 on: August 13, 2010, 04:22:20 pm »
I'm not at home, so I can't be 100% certain on this, but I'm pretty sure Windows 7 tells you what other program your file is in/
MonMotha
« Reply #6 on: August 13, 2010, 04:27:36 pm »
One of the nice things about Linux, though, is that you can move or even remove something with an open file handle on it (but not a mandatory lock, though these are rarely used) without invalidating the file handle.  In the case of moving a file, the file handle continues to point to the moved file.  The old path isn't valid, but once the file is open, the path doesn't matter.  In the case of removing a file, the file handle remains valid, but no new handles can be opened and it wont show up in listings.  Once the last handle is closed, the file is finally removed.
Windows is quite a bit more anal.  Both options have their advantages and disadvantages.  In the face of poorly written software which sometimes closes and re-opens a file for writing upon "save" using the original pathname, the Linux (used by most UNIXes) can result in files showing back up with new content (and the moved file having the old content), and I think there are a lot of Windows apps that do this, so I can guess that's why MS has stuck with their current approach since forever.  That may also be the way VMS handles it, and NT is based upon VMS.
Incidentally, simply performing an action on a file in Linux won't tell you what processes have a handle on it.  You need something like lsof to tell you that, but said command is pretty common.  Some GUI file managers may implement this function for you.
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #7 on: August 13, 2010, 05:43:43 pm »
It only does that when THE FILE IS OPEN IN A PROGRAM! Hello! Close the program or file.  :dunno
NO MORE!!
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:April 05, 2026, 08:28:15 am
« Reply #8 on: August 13, 2010, 06:21:20 pm »
Not true at all on Windows. Windows is notorious for having a program shut down but the file lock not being released. Annoys the crud out of me.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
shmokes
    • Jake Moses
« Reply #9 on: August 14, 2010, 09:57:27 am »
 ::)  I think when you were reading my post you missed the part about pretty much the whole thing.  Reread.
Best Kid iPad Apps
