Author Topic: K7000 dim white  (Read 1590 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
K7000 dim white
« on: August 04, 2010, 09:24:06 pm »
Hi
I am just after capkit and rejuvenation of WG k7000 25". The colours are great, except white. White colour seems to be a little dim, compared to RGB. Is there any way to improve/readjust it?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: K7000 dim white
« Reply #1 on: August 04, 2010, 10:02:25 pm »
it usually takes a little time for the guns to settle after a rejuve .  ;)
assuming white balance is correct,
u may need to adjust the black level
reduce brightness and contrast levels to low levels.
adjust screen ctl ( usually lower pot on flyback ) until an image is JUST barely perceptable .
then adjust brite/contrast to desired levels.
Kevin Mullins
    • Me on Myspace
Re: K7000 dim white
« Reply #2 on: August 05, 2010, 10:53:58 am »
Yeah, what he said.......
If your RGB all look good (bright/solid), then your white may be just that one of those adjustments is a hair off.
So basically it boils down to a bit more adjustment.
Just takes some fiddling with it.
