Author Topic: JPAC  (Read 4217 times)
presicion25
  • Last login:October 22, 2010, 04:21:06 pm
JPAC
« on: July 29, 2010, 08:30:18 am »
Wondering if anyone can shed some light on this. I recently put  PC into a candy cab I have. However, when I boot it, the split signal from the JPAC shows up, then the screen turns to scrambled blue. I dont have the PC booting directly into MAME, does anyone think thats the problem?  ???
Or could it possibly be my VGA card. The motherboard is from an HP built in 2004. Its got a 2.6ghz processor and 512mb RAM.
Im stumped here.  :-[  If I cant get it to work, I may use it for a bartop project.
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: JPAC
« Reply #1 on: July 29, 2010, 08:36:03 am »
What resolution/horizontal refresh are you running at ? What kind of monitor do you have ?
Working: Not Enough
Projects: Too Many
Progress: None
presicion25
Re: JPAC
« Reply #2 on: July 29, 2010, 08:54:59 am »
The cab im using is a Crowin Case, its a Korean Candy Cab. the monitor is made by Samsung and I believe its a 15KHZ monitor, or thats what I was told. I thought maybe it s got to do with the fact im not booting directly to mame. But im not sure.
Heres my exact cab:
http://hard--candy.com/index.asp?page=CWC-203
CheffoJeffo
Re: JPAC
« Reply #3 on: July 29, 2010, 08:56:50 am »
OK, so do you have your video card set up to drive at 15Khz ?
Working: Not Enough
Projects: Too Many
Progress: None
Re: JPAC
« Reply #4 on: July 29, 2010, 09:06:38 am »
+1
you running either Soft15 or an Arcade VGA?
presicion25
Re: JPAC
« Reply #5 on: July 29, 2010, 09:09:21 am »
You guys are probably right. Im running whatever the motherboard came with and the vga card may not be enough.
Im going to try tonight to see if i can set the vga to run at 15khz, as soon i figure it out lol
Ive never heard of soft15 but ive seen a newer vga card for sale on ultimarc.
Thanx for you guys help though.   ;D
Does anyone know where I can get any pre-made boxes for building a controller of my own? Im not good at wood working.  :-[
« Last Edit: July 29, 2010, 09:13:15 am by presicion25 »
Re: JPAC
« Reply #6 on: July 29, 2010, 09:33:43 am »
soft 15 is discussed here, in the software subforum. it allows a wide range of cards to do what the arcade VGA does, and thats output at 15hz
« Last Edit: July 29, 2010, 09:36:35 am by Malenko »
presicion25
Re: JPAC
« Reply #7 on: July 29, 2010, 09:53:40 am »
Thank You.  :)
BobA
  • What Me Worry?
Re: JPAC
« Reply #8 on: July 29, 2010, 05:41:53 pm »
NC Customs Sells Control Panel Kits
« Last Edit: July 29, 2010, 09:33:05 pm by BobA »
