Author Topic: WG 25K7131 issues  (Read 1956 times)
optima23
  • Last login:August 02, 2010, 12:37:17 am
WG 25K7131 issues
« on: July 29, 2010, 01:46:36 am »
ok so I just picked up a police trainer game and the monitor is not working. So I started trouble shooting and I have found the blown fuse on the monitor board and I have also verified that the IC4 pin to the transistor is shorted. So been reading a little and looks like quite a few things could be causing this. Weres a good place to start looking for parts or what kind of monitor can i look for to just change out complete. (any newer monitors that might work and what would be needed for a change over.)
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG 25K7131 issues
« Reply #1 on: July 30, 2010, 09:39:05 pm »
the hout xistor is likely shorted ( 2sd1398 ) and took out IC4 ( str30123)
the cause is most likely a value change of c57 ( 47uF/160v) use 105 degree when replacing...
that should get you started .
optima23
« Reply #2 on: July 31, 2010, 12:06:35 am »
wheres a good place to get parts?
qrz
« Reply #3 on: July 31, 2010, 09:37:26 am »
