Author Topic: Help with Ms. Pacman/Galaga Cabinet  (Read 5152 times)
NeoFlynn
  • Last login:October 17, 2011, 02:03:31 am
  • New Vegas Here I Come...
    • Neoflynn's Randomness, Rants and Reviews
« on: July 25, 2010, 10:56:00 pm »
I inheireted a Ms.Pacman/Galaga Cabinet here is the problem I am having with it, The coin door is locked and I dont have the key for it and the machine is currently not set to free play and wont accept any coins, is there anyway to set it to free play with out access to the coin door or am I going to have to break into the coin door to be able to use it?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Help with Ms. Pacman/Galaga Cabinet
« Reply #1 on: July 26, 2010, 11:12:42 am »
Do you have access to the back door?
NO MORE!!
NeoFlynn
« Reply #2 on: July 26, 2010, 04:23:01 pm »
yes I did manage to pry the back open but I dont see any kind of reset or anything, and I have no idea about how to manipulate the board in any way I am a complete novice when it comes to these things
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
« Reply #3 on: July 26, 2010, 05:31:48 pm »
If you are in the back, you should be able to remove the screw holding the arm on the coin door lock.
Working: Not Enough
Projects: Too Many
Progress: None
Pinball Wizard
« Reply #4 on: July 26, 2010, 05:41:44 pm »
There is a board in the way to do that. Is it a Ms. Pacman or a Galaga? If you have access to the board you can flip the dip switches for the game. It all depends on what game you have as to what switches to flip.
Where's my gold star :P
RayB
  • There's my post
    • RayB.com
« Reply #5 on: July 26, 2010, 06:52:28 pm »
NO MORE!!
NeoFlynn
« Reply #6 on: July 26, 2010, 10:34:44 pm »
I'm guessing he has this:
http://www.chicago-gaming.com/Brochures/PacManual_Rev1.pdf
Yes RayB that is the cab in question though they mention a "faux" coin door and mine as an actual coin door, judging by that manual though sounds like my only option is going to be bustin into the coin door wich I hate to do but an un-usable machine does me no good either
ckong
  • Last login:October 19, 2020, 06:48:09 pm
  • Retro Games forever!
« Reply #7 on: July 27, 2010, 02:50:41 am »
Why not drill out the coin door lock?  ??? Google for 'how to's' on the www.
RayB
  • There's my post
    • RayB.com
« Reply #8 on: July 27, 2010, 11:44:34 am »
If you [have access through the] back, you should be able to remove the screw holding the arm on the coin door lock.
See Cheffo's comment above.
Also, took me 30 seconds to find that manual via Google, so perhaps you can find the one for the coin-op version.
NO MORE!!
CheffoJeffo
« Reply #9 on: July 27, 2010, 11:54:00 am »
Don't forget the wiki ... lots of sources for manuals.
http://wiki.arcadecontrols.com/wiki/Restoration
IIRC, everything is accessible via the TEST menu on that board.
Working: Not Enough
Projects: Too Many
Progress: None
BobA
  • What Me Worry?
« Reply #10 on: July 27, 2010, 01:13:50 pm »
NeoFlynn... Can you see the back of the coin door when you open the back of the cab?  If you can you just use a screw driver to unscrew the arm of the lock and release the coin door.  As this is a reunion cab I assume there is alot less stuff in the way since the PCB is so small.
NeoFlynn
« Reply #11 on: July 27, 2010, 05:01:46 pm »
Sadly no access to the coin door from the back there is a big piece of sheet metal blocking it with no way to remove it, I took a closer look at the actual PCB and i see a spot that says "test" but there is no switch or anything it is a square with 4 holes, 1 at each corner, I tried to snap a picture but its nothing but blur so i will have to try and manufacture some better lighting conditions and try again.  Dont know if I am supposed to use something to poke inside the hole to reset it or what, As I said I am a total novice with an actual arcade cabinet so I really appreciate all the help
CheffoJeffo
« Reply #12 on: July 27, 2010, 05:22:42 pm »
If you can't get at the coin door from behind, then drill the lock and see what is behind the coin door (most cabs with Test buttons have them behind the coin door).
Working: Not Enough
Projects: Too Many
Progress: None
NeoFlynn
« Reply #13 on: July 29, 2010, 12:08:23 am »
Well I finally decided to bite the bullet and try to pry open the coin door, and it was succesful and I should be able to dissasemble the lock and re key the thing if I decide i want to go that route, Thanks for all the advice you guys offered as soon as the door poped open there was the test button staring me in the face so I can finally enjoy my cab....Thanks again everyone :notworthy:
Q*Bert_OP
  • Oh yes, we did!
« Reply #14 on: August 06, 2010, 01:35:29 pm »
Don't re-key the lock...replace it. A new lock costs less than $4.
NeoFlynn
« Reply #15 on: August 06, 2010, 06:12:04 pm »
yeah thats what I meant by rekey, i meant replace, just came out wrong...LOL
