Author Topic: New Astro City Monitor Problem.  (Read 2650 times)
cobrakai22
  • Last login:June 27, 2011, 02:03:39 am
« on: July 23, 2010, 01:06:10 am »
Within this year i got a Sega New Astro City cabinet. I think the problem has been there since I got it the cab but its hard to notice when ingame but you can tell the top of the screen is a little crooked. More recently I've been more interested in finding out whats the cause just cause I don't want it to develop into something worse. This is my first crt cab so i'm not too good with diagnosing.
The monitor is a Nanao MS9-29S, in the pictures the problem is at the top left in all the pictures.
 I also circled the problem area in red. I have also went in and did every adjustment possible thru the monitor adjustment panel and this is the best I could get it straight. It is a really small issue but just wanna fix it before it leads to something else
I/O
  • Last login:June 06, 2011, 01:33:10 am
Re: New Astro City Monitor Problem.
« Reply #1 on: July 23, 2010, 05:32:40 pm »
A pretty minor impurity. Look up convergence and color purity, you may be able to fix it. You might not want to - unless it does get a bit worse.
cobrakai22
« Reply #2 on: July 23, 2010, 07:06:19 pm »
Zebidee
  • Trade Count: (+9)
  • Last login:Today at 04:49:30 pm
« Reply #3 on: August 10, 2010, 11:48:32 pm »
You could probably fix that minor convergence problem by using a small magnet (I mean a monitor magnet, similar to a fridge magnet) in just the right spot. Or you could just live with it - it isn't really very obvious.
