Author Topic: crudded up computer  (Read 2718 times)
LLUncoolJ
  • Last login:April 23, 2015, 03:08:00 pm
  • This snowflake tastes like fish sticks!
crudded up computer
« on: July 20, 2010, 05:28:19 pm »
Today my work computer was all crudded up with malware. Not sure how, as this sight is probably the most questionable of the sites I access with it. We deploy McAfee, but the crap gave it the slip. Anyway, spent half the day battling it, and while I'm not a real IT person, I'm the closest thing our company has in-house. I think I beat it and here were the tools:
First downloaded Malwarebytes and ran it. It found 5 instances and terminated them, thought I was in the clear. Scanned it with MB again, then scanned it with McAfee...nothing.
Then, every now and then a random IE window would open with a Lycos search in it. So I tried GMER, which crashed my computer at a different point in the scan 5 times.
Then I downloaded tdskiller and ran it. Took all of 15 seconds and found and eliminated the critter. So far, so good...knock on wood.
So I hope this helps if you get crudded up any time soon. :cheers:
You probably remember me from such films as `The Revenge of Abe Lincoln' and `The Wackiest Covered Wagon in the West'
Gameroom pics at http://forum.arcadecontrols.com/index.php?topic=89006.40
  • Last login:May 30, 2026, 12:00:14 pm
Re: crudded up computer
« Reply #1 on: July 20, 2010, 09:27:43 pm »
Turn off system restore, run malwarebytes in safe mode.
Turn restore back on after it's clean.
Ed_McCarron
« Reply #2 on: July 20, 2010, 09:29:05 pm »
Before running MWB, run rkill.  It'll terminate most known malware processes and let you run other things.
It's updated fairly often, so make sure you get a fresh copy.
« Reply #3 on: July 21, 2010, 03:34:52 pm »
www.bleepingcomputer.com/combofix
^godsend
Ive used it 3 times, only once for myself. Worked perfectly and its free. It works so well I donated , and that means A LOT.
newmanfamilyvlogs
    • Newman Family Vlogs
« Reply #4 on: July 21, 2010, 04:09:34 pm »
+1 on rkill.
I've got two computers on the bench behind me chewing away on some AV scans, and you can't do jack on them until you run rkill first.
8way
  • Last login:February 03, 2017, 05:52:21 am
  • This is my BOOM stick!
« Reply #5 on: July 22, 2010, 05:21:34 am »
Reinstall fresh copy of windows. Best solution.
newmanfamilyvlogs
« Reply #6 on: July 22, 2010, 06:19:03 am »
Only for very low values of 'Best' (:
