Author Topic: dreamcast to vga box to vga to component converter to component tv work?  (Read 2945 times)
northerngames
  • Trade Count: (+18)
was wondering if I could hook up the dreamcast to a component tv through the vga and adding a vga to component converter and still have the higher resolution display with nothing goofy.
or is there a hard mod to make the DC do component off the mobo?
« Last Edit: July 14, 2010, 02:10:03 pm by northerngames »
Ginsu Victim
  • Last login:June 28, 2025, 10:45:55 pm
  • Comanche, OK -- USA
I've tried and couldn't get it to work.
northerngames
dang I am shooting for a display that can do the DC in vga and gamecube in component res's.
I have a VW246H 1080P wide screen that works great for the 360 and would work for them also but I like the ol CRT vga boxed screen for the cube and DC they just dont look right shape wise on the wide screen.
I would like to get a gateway destination or similair but thought if I could get the DC to go component then I could get away with a component TV instead of a large vga CRT as there getting harder to find and the shipping is a deal breaker everytime  :badmood:
voltz
  • Last login:February 14, 2018, 01:17:59 am
To be honest with this question, you typically can't get the vga to convert to component unless you have a specific vga to component transcoder.  You can check for those on ebay.
Moff's the Stuff!
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
Re: dreamcast to vga box to vga to component converter to component tv work?
« Reply #4 on: September 29, 2010, 10:51:16 pm »
Is the vga box any different then hacking vga directly into the DC? I put a VGA port on the back side of the DC but I dont have one of them fancy comp cables.
