Author Topic: Mr. G's Green Screen  (Read 1693 times)
Mr. Greenjeans
  • Last login:July 10, 2013, 03:51:51 pm
« on: July 13, 2010, 05:05:37 pm »
Picked up a cherry master machine the other day and this is all i get when i fire it up.
Is this a monitor issue (13" Electrohome GO7) or an issue with the pcb itself? It does have some corrosion on the edge connector where the video is going out, which I tried to clean but it still had the same results.
Mr G.
« Last Edit: July 13, 2010, 05:20:51 pm by Mr. Greenjeans »
SirPeale
  • Green Mountain Man
Re: Mr. G's Green Screen
« Reply #1 on: July 14, 2010, 09:08:48 am »
Possibly both.  Eliminate the monitor as a problem by hooking another signal up to it.
lilshawn
  • Last login:July 01, 2026, 04:44:09 pm
« Reply #2 on: July 16, 2010, 04:24:49 pm »
are those lines moving around or are they static?
Mr. Greenjeans
« Reply #3 on: July 20, 2010, 10:25:58 am »
They are moving. I don't have anything else to hook up to the monitor at the moment to rule it out.
