Author Topic: Discharge tool question  (Read 3143 times)
« on: July 09, 2010, 11:17:58 pm »
I've watched several videos on how to discharge your monitor.  Most of them describe creating a tool using a screwdriver, banana clip and heavy gauge wire.  A couple of the videos mention using an insulated screwdriver but the in the videos it looks like they are using a regular screwdriver.  The insulated screwdrivers I have seen have protection on the shaft as well as the handle.
To those who have done this I'm wondering if you need an insulated screwdriver or if a regular screwdriver will work?
cw
  • Last login:March 26, 2026, 09:24:03 pm
  • Game over man game over
    • The Cab
Re: Discharge tool question
« Reply #1 on: July 10, 2010, 12:50:36 am »
a screw driver that has the metal shaft formed into a plastic molded handle.. in other words something thats not going to send the voltage from the tube right down your arm....
korendog
  • Last login:May 05, 2011, 03:24:14 pm
  • The squeaky wheels gets the grease!
« Reply #2 on: July 10, 2010, 03:11:23 am »
Bob Roberts sells them on his site.  If you are going to be in this hobby and plan on working on monitors I would suggest picking one up.
Capcom Bowling, Star Wars (Cockpit), Karate Champ, MAME (Vertical)
« Reply #3 on: July 10, 2010, 06:31:35 pm »
I ended up building one following Bob's directions.
http://www.therealbobroberts.net/sb.html
Worked like a charm.  I used a standard screwdriver.  Actually had the exact one in his example except mine was a phillips.  Five minutes on the grinder and it became a flathead.
Thanks for the help.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: July 11, 2010, 12:54:35 am »
I have a few high voltage probes that are rated for up to 50k volts. They cost about $1000 each new, but I picked them up from a bankruptcy auction for pennies on the dollar. Before I had those, I used a flat head screwdriver with an alligator clip test jumper wire. I'm still here, so that method didn't kill me. :dizzy: You should be fine using the "old fashioned" method. The kit that Bob Roberts sells permanently attaches the wire to the screwdriver, so that's probably safer.
« Reply #5 on: July 11, 2010, 09:48:08 am »
I looked for one of those probes a while back.  Seemed like a better way to go but I could not find as good a deal as you found.  Congratulations on your score.   :cheers:
I'm really glad I was pointed to the Bob Roberts tutorial.  I never thought to drill through the screwdriver and feel better knowing the wire will not come loose.
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #6 on: July 11, 2010, 09:34:35 pm »
Q*Bert_OP
  • Oh yes, we did!
« Reply #7 on: July 12, 2010, 08:46:36 pm »
::)   a reasonably priced hv probe here :
http://www.mcmelectronics.com/product/72-6530&mybuyscid=12399594715
Ok...but I paid less than that for all 3 that I own combined. I also got 2x 4 channel digital oscilloscopes for $100 each from that auction.
jimmy2x2x
« Reply #8 on: July 12, 2010, 08:49:34 pm »
Once you have successfully discharge the monitor, multiple times in 5 min intervals
you remove the anode cap
work on the monitor
then replace the cap with your fingers?
Ive never done this, but will need to soon - im getting a jamma cab with monitor tomorrow and could do without any surprises!
Q*Bert_OP
  • Oh yes, we did!
« Reply #9 on: July 12, 2010, 08:54:55 pm »
work on the monitor
Use the screwdriver to push out one of the prongs under the cap, then pull the cap out. When you go to put the cap back on, discharge again in case any residual charge built up, place one prong in, then use the screwdriver to push in the other prong.
I don't do the "interval thing"...once is good enough to remove the cap...when the chassis is unhooked, there is no power in the high voltage circuit, so while the cap is removed, you don't need to worry. Just make sure to discharge the tube before reattaching the anode cap. Be careful when touching the underside of a chassis that was recently powered on...the large filter capacitors hold a charge for a long time.
