Author Topic: Would this Cutter work for this T-Moulding?  (Read 5008 times)
jimmy2x2x
Franco B
Re: Would this Cutter work for this T-Moulding?
« Reply #1 on: July 08, 2010, 05:52:57 pm »
No, I'm afraid that won't be suitable for t-moulding. Its a bit for cutting slots for biscuits and so will cut a slot ~3.75mm wide.
Looking at the listing, all of the t-moulding they supply requires a 1.5mm (1/16") slot apart from the black/chrome stripe which requires a 2mm (5/64")slot.
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
« Reply #2 on: July 09, 2010, 04:34:41 pm »
i used a 2 mm metric slotcutter with my bosch router for molding up to 1 inch. it worked perfect.
jimmy2x2x
« Reply #3 on: July 09, 2010, 04:37:57 pm »
Im trying to find a cheap option in the UK.
These are the ONLY ones I have found, and they are out of stock!
http://www.rutlands.co.uk/power-tools-&-accessories/router-cutters/slot-cutters/TR239/slot-cutters-with-arbors-&-stiffening-collars
The Lumberjackass
  • Last login:January 09, 2015, 08:58:56 pm
« Reply #4 on: July 09, 2010, 09:00:21 pm »
UPDATED
hi jimmy, you need to visit axminster.co.uk.
they have the slot cutter you need. its where i buy most , if not all of my hardware.
here is the slot you need :
http://www.axminster.co.uk/cmt-cmt-three-wing-slot-cutters-prod20957/
you need the 1.5mm as its the closest match , order no is 822315
here is the arbour : ( the slot cutter connects to this )
http://www.axminster.co.uk/cmt-cmt-slot-cutter-arbors-prod20960/
depending on what router you have , you must choose if its a 1/4" or 1/2" shank ( what fits your router ).
you will also need a bearing :
http://www.axminster.co.uk/cmt-cmt-router-cutter-bearings-prod20906/  order no is 341191
the bearing your looking for is the 28mm one , use the order code to select the correct one.
buying all 3 is expensive , i understand that , but thats what happens when you need to use professional tools.
regardless, these 3 items will cut the slot you wish .
« Last Edit: July 10, 2010, 01:25:23 pm by The Lumberjackass »
I may be a jackass , but im no fool !
Dr_Dave
  • Last login:December 04, 2011, 03:57:47 pm
« Reply #5 on: August 06, 2010, 03:35:45 am »
Hi Chaps,
Quick question about those axminster recommendations...
The bearing linked to has an internal diameter of 12mm. To my amateur eye, this seems too wide to sit on a 1/4" shank. Have I missed something about how these things fit together? Or does a 1/4" shank need a bearing with a smaller internal diameter?
Cheers
Dave
« Last Edit: August 06, 2010, 07:00:44 am by Dr_Dave »
The Lumberjackass
« Reply #6 on: August 06, 2010, 11:49:48 am »
the bearing which i listed is for the half inch arbour , as thats the hardware which i used.
but just to be on the safe side , and not to give any false hope or information , contact axminster directly and
ask them do the bearings fit both the half inch and the quarter inch.
i would say they do , but ask them just to be sure.
