Author Topic: neo-tec nt-2701  (Read 3342 times)
wackamole
  • Last login:July 16, 2012, 12:00:43 pm
neo-tec nt-2701
« on: June 29, 2010, 11:01:52 am »
im working on this unit and c419 is open and it has a 822j/1.6kv in it but the manual shows 123j/1.6kv so witch one should i use help
wackamole
Re: neo-tec nt-2701
« Reply #1 on: June 29, 2010, 02:34:50 pm »
i put new cap in and still shorts the HOT and opens up c219 dose anyone know what more i can check  :banghead: :banghead:
grantspain
  • Last login:Yesterday at 04:42:18 pm
Re: neo-tec nt-2701
« Reply #2 on: June 29, 2010, 07:31:44 pm »
isolate the flyback and use the lightbulb trick
Ken Layton
  • Guru
  • Technician
Re: neo-tec nt-2701
« Reply #3 on: June 30, 2010, 12:34:15 am »
Use what was in it. Neotec manuals are riddled with errors.
The cap is probably a "Metalized Polypropylene" type made for horizontal output stages. Ordinary caps will fail immediately.
822 = .0082 uf @ 1600 volts
lilshawn
Re: neo-tec nt-2701
« Reply #4 on: July 01, 2010, 01:02:06 am »
Replace them with what was originaly there. Ignore what the schematic says.
BTW those dipped caps should read open if your doing a contenuity test on them.
wackamole
Re: neo-tec nt-2701
« Reply #5 on: July 08, 2010, 03:35:14 pm »
update: got new flyback from neo-tec today rechecked c419,c421,c423,d403,replaced the HOT fired her up and.....got.......the famous ticking,bird cherp and blow the HOT  :banghead: ??? :hissy: :censored:
Ken Layton
  • Guru
  • Technician
Re: neo-tec nt-2701
« Reply #6 on: July 08, 2010, 11:02:51 pm »
Neotec's service department can repair the chassis if you send it to them. You can also send it to Chad at Arcadecup.com
