Author Topic: Generating list for FE  (Read 1465 times)
Demon-Seed
    • DemonCade (WORKING URL!)
« on: June 14, 2010, 09:16:35 pm »
Hello
I am currently running latest mamewah with older mames (.37b16, .62)
I want to make a list in mamewah with all my working games that i have.  I used romlister for .98 etc which works great however you must have a xml file to use it.
I have download corresponding dat, and it lists all the games rom_folder_vs_dat_file, however I get annoyed... as for example there is like 6 versions of streetfighter zero 2 and of the 6. 3 are bad.l.. I want to scan the roms and only working ones show?
Older mames do not use xml.  Is there a tool out there to create lists but show the names not the zip names? of the games that I have?  I amnot sure how ...pls help
thnks
Jim
« Last Edit: June 14, 2010, 09:27:13 pm by Demon-Seed »
dungbeetle46
  • Last login:June 25, 2016, 07:27:47 pm
Re: Generating list for FE
« Reply #1 on: June 15, 2010, 02:42:17 am »
try romcentre that will show the rom names and repair any if needed
gonzo90017
« Reply #2 on: June 18, 2010, 11:25:49 pm »
Download the dat file for your version of mame from here. (make sure it's the (cm) version)
Put it inside your mame folder. Then modify the a couple of lines in the .ini file for mame. The one inside Mamewah\config
Code: [Select]
dat_file                                  C:\juegos2\mame36\Mame36.dat
Code: [Select]
list_generation_method                    rom_folder_vs_dat_file
Then open mamewah and generate a list.
Demon-Seed
« Reply #3 on: June 19, 2010, 05:33:14 am »
hey
Thanks I figured it out... had to use the dat file to make the list THEN make filtered list with catver.ini!!
thanks all
Jim
