Author Topic: Broken Neck/ Monitor Orientation Question  (Read 2142 times)
mike boss
« on: May 26, 2010, 05:04:42 pm »
I was working on one of my bartop arcade units.
I had to move the monitor so that I could mount it on the supports.
I gave it a lil jolt and the next think you know I hear a sound like air leaking out of a tire.
Any idea what I did ? And have I know completely fuct the monitor ?
* as of the know the cabinet wiring is not complete, so I am unable to test the monitor *
any help would be greatly appreciated.
thank you
« Last Edit: May 26, 2010, 05:19:33 pm by mike boss »
grantspain
  • Last login:July 25, 2025, 09:21:43 am
Re: Monitor/Sound/Air Leak
« Reply #1 on: May 26, 2010, 05:14:31 pm »
sounds like you bust the neck of the tube-therefore you will need a new crt
mike boss
« Reply #2 on: May 26, 2010, 05:16:55 pm »
thank you, I was scared it was something like that.
Luckily this is in the machine I plan on keeping.
So i think I might try my hand @ a used LCD monitor.
I believe it will hook right up into the 48-in-1 board.
Now if only it fits into the cabinet.
mike boss
Re: Broken Neck/ Monitor Orientation Question
« Reply #3 on: May 26, 2010, 05:21:42 pm »
I apologize if this is not in the most ideal of sections.
As per the above post it would appear I have damaged my bartop monitor.
As opposed to finding a replacement I've decided I will try using a LCD PC monitor.
However 48-in-1 game boards require a vertical mounted monitor.
Based on the sizing I was sent I dont think it will fit.
Does anyone know if the 48-in-1 board has the ability to rotate the image ?
This way I can display a vertical image on my horizontal monitor.
Thank you
Kevin Mullins
    • Me on Myspace
« Reply #4 on: May 26, 2010, 05:41:48 pm »
Simple answer.... no.
mike boss
« Reply #5 on: May 26, 2010, 06:39:28 pm »
Ah man, now I really am S.O.L !
Not having a good few weeks when it comes to electronics.
My new HP Laptop HDD goes...........
one of my 17" ELO touchscreens,
and now this ! GRRRRRRRRRRREAT !
thanks guys for the info.
So now the search begins for an LCD I can fit inside and rotate !
delta88
  • Last login:May 20, 2025, 08:21:05 am
  • This place is still here?
« Reply #6 on: May 29, 2010, 02:12:24 am »
Just P/u A 13" CRT OR WHATEVER IS IN IT NAD BE DONE WITH IT?
Or type in all caps and spell wrong @ 2:13in the AM,,, :dunno
