Author Topic: Removing Clones and multiple versions.Sorting by control type.  (Read 1815 times)
tagnetti
  • Last login:January 25, 2009, 01:31:02 am
Hello everyone. I am setting up my first Mame cabinet and wiring it this week thanks to Birdtales.
Does anyone know if there is anyway I can run a program that removes clones and duplicates of the same game? I am having trouble discerning which version of games is best as some have 5and 6 versions.
I heard someone mention a romchecker to validate all roms. any info on that is appreciated.
Also in Mamewah is there any way to sort games by control type as I am going to have 2 different control panels and would like lists that correspond with each.
Appreciate the help.
Tom
Re:Removing Clones and multiple versions.Sorting by control type.
« Reply #1 on: August 01, 2003, 11:44:14 am »
Well since you are using MAMEWAH, generate a custom list to remove the clones (Games List Options > Generate Custom List using Filters).
You can use the above method to generate lists based on controller (Input type) as well :)
tagnetti
« Reply #2 on: August 01, 2003, 12:43:10 pm »
Thanks. Can you expand on that direction or clarify for me. I went in and have no trouble adding to a custom list but I don't see a using filters option. Perhaps I am misunderstanding or do I need to edit a certain text file and specify certain parameters?
Also once I do that I wonder if there is a way to single out those removed titles and delete them freeing space.
Appreciate it
« Reply #3 on: August 01, 2003, 01:11:24 pm »
Appreciate it
You need to select the custom list you wish to use first - then the 'Generate Custom List using Filters' option will appear in the Games List Options menu.  That's all you need to do :)
There is no way of actually deleting the ROMsets you don't want.  You would have to do this manually, although I personally wouldn't bother!
tagnetti
« Reply #4 on: August 01, 2003, 01:13:23 pm »
Great. Thank you. You did an awesome job with that and appreciate your hard work. If you ever need any graphic work. I am a 3d animator and illustrator. I might be able to contribute.
Also one question Is there a way to move allgames to a custom list so it can pull from them to sort or do you point to another directory when filtering.
Tom
« Last Edit: August 01, 2003, 02:21:25 pm by tagnetti »
« Reply #5 on: August 04, 2003, 05:27:12 am »
You can use the 'Generate Custom List using Filters' menus to generate a list of all games by say turning off clones, then on again (or alter altering any filter like that).
Not sure if that is what you meant?...
