Author Topic: 5/8 plywood  (Read 3813 times)
johnd23
  • Last login:December 11, 2023, 12:57:59 am
5/8 plywood
« on: May 23, 2010, 01:59:50 am »
So I've been playing with the design of the cabinet I plan on building. I'm going to be following the Lusid plans, but slimming it down about 12" (in depth) because i'm going to use an LCD. I would like to go with plywood vs mdf to save on weight. I am looking to use 5/8 plywood.. the closest i can find around here is 19/32 which is only 1/32 off. Anyone else use that size before? I plan on using laminate on both sides which should bring it up a hair smaller than 3/4. I can only find that size plywood in CD grade or sheathing. Being as I am going to be using laminate it shouldnt matter about the grade correct?
For the control panel i plan to use the same 19/32 and then get 1/8 plexi and 3/4 tmolding. I'm hoping to start the control panel tomorrow if everything goes as planned.
syph007
Re: 5/8 plywood
« Reply #1 on: May 23, 2010, 08:02:42 am »
Ya I couldnt find 5/8 in a good grade at home depot here either.  I bought a low grade, but once the laminate went on it's fine, you cant tell at all.  Only extra thing I had to do was wood fill a few knot holes.
dawolv
  • Last login:March 25, 2016, 08:23:21 am
Re: 5/8 plywood
« Reply #2 on: May 24, 2010, 12:35:22 pm »
Did your 3/4 T-Mold sit flush with the Laminate and the 5/8 ply?
The reason I ask is, I recieved my sample 3/4" T-Mold from T-Molding.com but after installing it in a 3/4" ply test piece I have about an 1/16th on each side that is sitting proud.
I just recieved the 5/8" samples but have not check them in the test piece yet.
I also havent been to Home Depot to check the thickness on the Laminate, I was going to paint but after all the "looking back" advice here, I will probably laminate especially if its a 1/16" thick  :laugh:
syph007
Re: 5/8 plywood
« Reply #3 on: May 24, 2010, 12:42:00 pm »
Yep it was a tiny bit bigger, but ended up working out better.  I ran a chisel at 45 degrees along the entire edge and it trimmed perfectly flush.
