Author Topic: Melamine?  (Read 1923 times)
Thom
  • Last login:July 07, 2010, 12:13:35 am
Melamine?
« on: May 09, 2010, 08:38:14 am »
I'm in the initial planning stages of my first MAME cabinet. I'm leaning toward using NorthCoast Custom Arcade's "Ultimate Arcade II" plans as a start for the cabinet. I can't find 5/8" MDF anywhere around here, so I'll be using 3/4". A Lowe's store in my area has 3/4" 2-sided White Melamine for just $0.99 a sheet more than regular Melamine ($32.97 for a 3/4" x 49" x 97" sheet).
What are the pros/cons (if any) of using Melamine, as opposed to laminating regular MDF?
One other question, while I'm at it. In regards to laminating, I'd be starting with a 3/4" piece of MDF. I'd add the thickness of the laminate to the piece, then I'd use a 3/4" piece of T-molding on the edge. Wouldn't the laminate stick out past the T-molding? Or is the laminate so thin that this isn't an issue?
Thanks,
Thom
BobA
  • What Me Worry?
Re: Melamine?
« Reply #1 on: May 09, 2010, 08:46:03 am »
Melamine is very thin and almost a non issue in adding to the size of the MDF.   The thinness is a problem as it can chip very easy.  Look up info on cutting melamine covered MDF and you will probably find info on the blade to use to cut it and info on taping and other methods to reduce chipping.   It is best cut on a table saw where the blade depth can be controlled.
One link of many from Google
« Last Edit: May 09, 2010, 09:34:15 am by BobA »
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
Re: Melamine?
« Reply #2 on: May 09, 2010, 09:30:58 am »
I have built 2 cabs one in 3/4 MDF and another in 5/8 particle board and if you are going to laminate the sides the particle board will be fine and less weight. Then you can choose the colors you want instead of being stuck with the white if that's not your preference. Good luck with your project.   :cheers:
syph007
Re: Melamine?
« Reply #3 on: May 09, 2010, 11:22:37 am »
The laminate I'm using is almost 1/16 the inch.  I used 5/8 wood and with laminate on both sides it was just about equal to 3/4.  If you only put it on one side and paint the other, I'd say you could get away with 3/4 inch wood though.
bkenobi
Re: Melamine?
« Reply #4 on: May 10, 2010, 03:39:08 pm »
Melamine only works if you like the limited color choice.  I wouldn't personally want a white cabinet.  I suppose if you are putting massive side art on, then it wouldn't be quite as bad though.
BobA
  • What Me Worry?
Re: Melamine?
« Reply #5 on: May 10, 2010, 07:09:16 pm »
Most kits and prebuilt cabs use black melamine on particle board as it is one of the most cost effective materials.
DEMENTED
  • Last login:May 24, 2012, 11:10:17 pm
Re: Melamine?
« Reply #6 on: May 12, 2010, 10:39:09 pm »
In the US melamine coatings are almost exclusively applied to particle board.  As previous posters have mentioned you need the right tools / blades for good cuts on particle board.  Another problem is assembling the finished pieces.  Standard woodworking adhesives will not give the best results on melamine.   Also consider the destructive effects of water on particle board.   You also asked about laminate.  Laminate thickness depends on the type.  From thinest to thickest the types are Vertical grade, Post forming grade and Horizontal grade.    If the laminate you are considering is an in stock item at a home store (Lowes, Home Depot, etc.)  it will almost certainly be the thickest type.  Vertical grade for the vertical sides of your cabinet would be more than adequate.   If I wanted laminate I would contact a custom counter top / cabinet business.   Ask them to order a sheet or two of vertical grade in your desired color with their next order.  They will also probably have more color samples.
