Author Topic: Double Toggle switch??  (Read 3177 times)
H4CK3R
  • Last login:November 16, 2012, 06:12:09 am
« on: May 05, 2010, 03:38:13 am »
I need a Button that can trigger two different controllers at once.  One if for an Ipac, the other for a 18 Volt solenoid.  Both need to go off at the same time.
I have seen some, but I have to order 1,000 of them at a time...  Anyone have anything that can work?  Or know where I can get something that will?
H4CK3R
scuba465
  • Last login:June 11, 2010, 04:20:16 am
Re: Double Toggle switch??
« Reply #1 on: May 05, 2010, 03:48:14 am »
Have you tried Radio Shack?
Work less Play hard
H4CK3R
« Reply #2 on: May 05, 2010, 03:55:23 am »
LOL.. Since your new, Ill let that slide... Hahaha
scuba465
« Reply #3 on: May 05, 2010, 04:07:45 am »
ok how about jamestown distributors? is that what your looking for. just trying to help. We had some at work but used them in some panels at work.
Work less Play hard
H4CK3R
« Reply #4 on: May 05, 2010, 04:14:57 am »
I appreciate it, Checking them out.  Thanks
H4CK3R
« Reply #5 on: May 05, 2010, 04:49:03 am »
Found this, anyone know of anyone that sells them Direct?
http://chinagreat2006.elec66.com/product-Other-Switches/30251/Double-Micro-switch.html
H4CK3R
Ed_McCarron
« Reply #6 on: May 05, 2010, 07:20:23 am »
Does it have to be an arcade type pushbutton like we're used to?
Could you take a standard microswitch arcade button, but instead of mounting the microswitch on the little studs that stick out, drill them and use small bolts to mount two switches side by side, then epoxy something across the bottom of the actuator so they both trigger at once?
« Reply #7 on: May 05, 2010, 07:48:35 am »
+1 on Ed's idea.
That or I was going to suggest using a Solid state relay or a an optoisolator. The button would then control one output AND the relay, the relay would control the other output, completely isolated from the first.
Mouser electronics is also a good place to pick up stuff like this.
mark shaker
  • Last login:March 04, 2022, 09:27:06 pm
  • Oh Crikey!
    • Mark's Basement Arcade
« Reply #8 on: May 05, 2010, 08:19:34 am »
You could also use a standard switch to trigger a DPDT Relay.
   - Mark
Marsupial
  • Last login:April 17, 2024, 09:00:56 pm
  • I am teh Mars!
« Reply #9 on: May 06, 2010, 12:58:14 am »
would you be able to simply put 2 switches? I mean, it would depend what poushbutton you have to hit the micro switch I guess, but that could be something to explore.
Have you tried APEM?
http://www.apem.com/
(likely in the snap action switches http://www.apem.com/snap.html )
try contacting them, they should know.
-Mars
SavannahLion
« Reply #10 on: May 06, 2010, 02:30:08 am »
Ummm... Maybe a PNP?
Seems to be the cheapest solution. About 3 cents/2000 units. Plus another couple of pennies for the necessary resistors and diode. Probably no more than 6 cents per unit per 1000? Not sure if you need a heatsink though.
I'm just guessing. Not sure if such a circuit will work with the signal line levels of an Ipac.
Ed_McCarron
« Reply #11 on: May 06, 2010, 07:20:45 am »
Well, you've got options now.  Since the OP asked for a switch, I tried to keep it non-electronic, but if -I- were doing this for myself, I'd probably go with the DPDT relay.  Take a spare voltage source, send that through the switch, and use it to pull in the relay.
Unfortunately, this is one of those 'theres a thousand ways to do it' scenarios.
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #12 on: May 06, 2010, 08:39:11 am »
Here is something  http://www.mouser.com/ProductDetail/Cherry-Electrical/E19-00A/?qs=sGAEpiMZZMsqIr59i2oRck%252brJF20sIm26c5oBAPK8bI%3d
Search the net for snap action switch dpdt
« Last Edit: May 06, 2010, 08:46:00 am by kegger »
syph007
« Reply #13 on: May 06, 2010, 11:06:57 am »
I just made one by gluing 2 together, then using a standard happ button as the button.  Its my main on/off for the arcade and i needed 2 buttons to be pushed at once basically.   You can see pictures here.  http://forum.arcadecontrols.com/index.php?topic=95768.msg1020332#msg1020332
BobA
  • What Me Worry?
« Reply #14 on: May 06, 2010, 11:25:44 am »
A dpst momentary switch will switch two contacts separately.
Link to example
H4CK3R
« Reply #15 on: May 06, 2010, 09:03:24 pm »
It needs to be an arcade switch. Micro switch to work, thanks for all the feed back, will create my own, or Find another work around, thinking of going with ED's idea.  Thanks tho =)
bkenobi
« Reply #16 on: May 07, 2010, 12:43:05 pm »
There are many types of "arcade" switches.  I bet you could even find something in a leaf variety that would work!
Ed_McCarron
« Reply #17 on: May 07, 2010, 01:54:29 pm »
Hm, didn't think of leafs.  Stack two sets of leafs with the little insulator standoff thingy and you're golden.
