Author Topic: How to do this split screen thing?  (Read 2463 times)
eds1275
  • Last login:August 28, 2026, 02:06:57 pm
  • Rock and Roll!
« on: April 21, 2010, 01:22:08 pm »
I was reading a post on Melenko's KI project when I noticed he had punch out and some other 2-screen games displyed on one monitor.
Like this:
How can I do the same thing? That looks pretty cool and though I'm using a horizontal widescreen monitor and though it will be small it opens up a bunch more games to play. Maybe one day even silent scope [that would be hella cheating though].
Congui
  • Last login:July 23, 2015, 12:54:53 pm
  • Newbie!
Re: How to do this split screen thing?
« Reply #1 on: April 21, 2010, 03:03:04 pm »
Hi there.
That's actually a playchoice version of Castlevania; all playchoice version play that way.  I personally don't like them too much cause the Menu Select screen is always there and take most of the screen space (unless you have a mame version that alows to hide it).  Other disadvantage to PlayChoice games is the built-in timer: you play the amount of time you purchased.  And also to start the game is quite different from other games.
Cheers,
Congui
creatine28
  • Last login:July 26, 2012, 03:41:48 pm
  • Which way to the Arcade?
« Reply #2 on: April 21, 2010, 03:08:30 pm »
Im using Mame 129.
I think if you hit tab and go into the Video setting of mame, it should be able to do what you're asking.  I've done it before for Punchout, I just cant recall exactly where I did it.   Just play around with the Mame setting within the emulator, it should be in there somewhere.
« Reply #3 on: April 21, 2010, 03:26:28 pm »
thats default settings, I dont recall changing anything. well I did just have the display output rotated to compensate for the vertical monitor.
