Author Topic: Hantarex Polo 2 28 inch questions  (Read 29624 times)
grantspain
  • Last login:Yesterday at 01:42:17 pm
Re: Hantarex Polo 2 28 inch questions
« Reply #80 on: May 07, 2010, 09:52:25 am »
but my chassis are both 220v right?  :notworthy:
hantarex polo 1 are 220v only
hantarex polo 2/star/polostar are 85v-255v
hantarex mtc9000/900 are 120v (u.k version requires 220vac for degauss as extra wiring)
njay
  • To Nudge or Not to Nudge !
« Reply #81 on: May 10, 2010, 08:39:17 am »
on which chassis connector (the two greenies)  did you stick the vid cable coming from the monitor? the top one ?
thanks :)  ;D
grantspain
« Reply #82 on: May 10, 2010, 12:45:32 pm »
thanks :)  ;D
the one infront of the remote board
njay
« Reply #83 on: May 10, 2010, 04:44:51 pm »
Cool , ow yeah i see a lot of monitor pictures here and usually the suction cup is sucked tight to the tube
but i cannot seem to get it like this when i connected both chassis the pins griped the inside but the suction cup stood outwards like it was going to get lose
grantspain
« Reply #84 on: May 10, 2010, 05:53:17 pm »
you must be doing it wrong
njay
« Reply #85 on: May 11, 2010, 03:14:43 am »
yeah i know that is why i am asking to learn
what i do:
1. pull back the rubber section
2. put one pin in the hole on the tube
3. try to get the other pin in
4. let go of the rubber
it will stick on my tube :( i cannot remove it so the pins are stuck but the rubber is not flat on the tube
grantspain
« Reply #86 on: May 11, 2010, 12:39:59 pm »
push the rubber flat
njay
« Reply #87 on: May 11, 2010, 02:22:56 pm »
lol as easy as that eh?
is it a huge issue when the rubber is not flat on ?
grantspain
« Reply #88 on: May 11, 2010, 02:27:08 pm »
yep as the ht will arc
njay
« Reply #89 on: May 12, 2010, 06:25:00 am »
First off thanks for all the info i really learn a lot from this
second i just remember when i put the neck board on its a little of center when compared to the monitor tube but it fits, i am asking this because i see a lot of pictures from tubes here with the neckboard centered with the tube
grantspain
« Reply #90 on: May 12, 2010, 12:24:41 pm »
should be dead centre-check your pins are not bent or maybe its just your eyesight
njay
« Reply #91 on: May 12, 2010, 05:22:08 pm »
two are top bent slighty but like said earlier the neckboard fits
grantspain
« Reply #92 on: May 12, 2010, 06:43:20 pm »
don't worry then
grantspain
« Reply #93 on: May 15, 2010, 08:00:37 am »
last chassis is all but repaired,just waiting for the correct flyback to turn up(company sent me a polo2 flyback)
runs with a polo 2 flyback but vertical scan is low and no brightness control
fix on this ticking chassis is flyback/possible leaky bu508a/change of a few leaky caps
njay
« Reply #94 on: May 15, 2010, 08:14:49 am »
nice really amazing work
now i have two good chassis sweet
