Author Topic: Galaga Lines  (Read 4491 times)
Bobby
  • Last login:January 14, 2016, 07:41:12 pm
Galaga Lines
« on: April 01, 2010, 04:09:48 am »
I have a Galaga game and its sick atm =[ any ideas on how to fix it here are some photos of it
-Bobby M.
Spyridon
Re: Galaga Lines
« Reply #1 on: April 01, 2010, 09:34:02 am »
First thing I would check is your power supply.  You can see how to test it here.
Bobby
Re: Galaga Lines
« Reply #2 on: April 01, 2010, 05:40:35 pm »
I think it maybe the power supply it read 2.1volts I try to turn it up but it didn't go up that much just .2 or so
Spyridon
Re: Galaga Lines
« Reply #3 on: April 02, 2010, 09:17:28 am »
Sounds like you need to rebuild your power supply
SirPeale
  • Green Mountain Man
Re: Galaga Lines
« Reply #4 on: April 02, 2010, 01:22:57 pm »
Though possible, @ 2.1V you shouldn't be getting much of anything at all.  Where did you measure from?
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
Re: Galaga Lines
« Reply #5 on: April 02, 2010, 02:21:55 pm »
Yeah that doesn't sound right. THe game would not even boot up with such low voltage.
NO MORE!!
Pinball Wizard
Re: Galaga Lines
« Reply #6 on: April 02, 2010, 06:50:35 pm »
Looking at this: http://www.arcadeshop.com/galaga/galaga.htm  If you scroll down some you'll find some things about RAM. That looks similar to your problem.
Where's my gold star :P
CheffoJeffo
  • Cheffo's right! ---saint
  • Worthless button pusher!
Re: Galaga Lines
« Reply #7 on: April 03, 2010, 09:57:20 am »
+1
Galaga is notorious for being thirsty and there is no way she would boot at 2.1V
Working: Not Enough
Projects: Too Many
Progress: None
Bobby
Re: Galaga Lines
« Reply #8 on: April 17, 2010, 01:35:31 pm »
I just check it with a 2nd meter and it shows to be 5volts for the first 5mins of boot up its fine after 5mins the lines start to show up
Kevin Mullins
    • Me on Myspace
Re: Galaga Lines
« Reply #9 on: April 17, 2010, 04:03:30 pm »
Could be heat related... I'd clean and re-seat any socketed chips. (ROM's, etc)
At the very least press them all in good.
SirPeale
Re: Galaga Lines
« Reply #10 on: April 17, 2010, 04:08:39 pm »
Definitely thermal related issue.  Chip "creep" would explain a lot of that.  I'd definitely reseat any socketed chips.
Bobby
Re: Galaga Lines
« Reply #11 on: April 17, 2010, 04:57:50 pm »
That was one of the first things i did when it went down took the rooms out and clean them and put them back in. is there any sites that may have them for sale?
SirPeale
Re: Galaga Lines
« Reply #12 on: April 17, 2010, 07:12:07 pm »
If it comes up good at first, but gets bad as it's on, it's not a ROM problem.
Are there other socketed chips?  Reseat them too.
Could also be a cracked solder joint.  Starts off okay, but as it heats up it looses connection, causing the problems.
Bobby
Re: Galaga Lines
« Reply #13 on: April 18, 2010, 02:30:23 am »
Do you think it might have anything to do with the chassis board or is it on the game board the board looks fine.
SirPeale
Re: Galaga Lines
« Reply #14 on: April 18, 2010, 07:13:45 am »
That's definitely a board issue.
Just to be straight: the game STARTS okay, but after a few minutes turns into the photo with lines as seen above.  Is that correct?
Bobby
Re: Galaga Lines
« Reply #15 on: April 18, 2010, 05:55:30 pm »
Yes Thats what it does. good for a few mins than turns into that.
Zebidee
  • Trade Count: (+9)
  • Last login:Yesterday at 07:28:20 pm
Re: Galaga Lines
« Reply #16 on: May 02, 2010, 08:14:05 am »
Did you check the power supply voltages AFTER the lines start showing up?
CheffoJeffo
Re: Galaga Lines
« Reply #17 on: May 02, 2010, 11:09:38 am »
Do any of the chips get really hot after those few minutes ?
Working: Not Enough
Projects: Too Many
Progress: None
channelmaniac
  • Last login:May 11, 2019, 12:36:18 am
    • Arcadecomponents.com
Re: Galaga Lines
« Reply #18 on: June 22, 2010, 12:37:34 pm »
Go to Fry's, Radio Shack, Maplins, etc... and pick up some component cooler spray.
If you can't find that then get a can of "air duster" spray and use it upside down so the liquid sprays out.
Cool off each of the 2147 RAM chips one at a time to see if the screen clears up when you freeze a particular chip. Replace that chip.
If it's not the 2147 RAM chips, there's a couple of chips that take the data from the motion RAM and adds in the other items such as scores/text. Check those. If that's not it then check the 74LS368 IC that buffers the clock on the video board. I've seen a bad one of those cause this issue too.
RJ
Call me a cheap bastard... I learned to fix things to save money... even surface mount soldering...
Visit my website: http://www.arcadecomponents.com
My repair logs are kept at: http://newlifegames.net/nlg/index.php?board=19.0
