Author Topic: Mamewah vs Dragon  (Read 1912 times)
Demon-Seed
    • DemonCade (WORKING URL!)
Mamewah vs Dragon
« on: July 28, 2003, 05:51:59 pm »
Hi,
I have been using DRAGON and have it running customized skins and running numerous emultors such as Nes, Snes, Gen, Snes, mame, Zinc, Pc games. I have been having problems with it crashing and mp3. I have been reading alot about Mamewah. I have never tried it and wondered how it compares? Can you use skins? can u use all emulators and reconfigure all the keys so that only your cp is used and no mouse or keyboard required? Can it play random mp3s?? just looking at some pros and cons of it before I try it.
thx
Jim
Demon-Seed
Re:Mamewah vs Dragon
« Reply #1 on: July 28, 2003, 06:04:15 pm »
one more thing. I got N64, PSX just about any emu running on Dragon but Nebula 2 and Kinsticnt. Can Mamewah run those? Can it run PC games? and how easy is it. Just need to know before I try!
thx in advance
Jim
  • Last login:Today at 04:01:29 pm
« Reply #2 on: July 28, 2003, 06:17:10 pm »
For the record both the u64 emu runs fine on dk.  I should know, I use it myself.  There is even a set of u64 specific wrappers if you'll look.   Nebula m2 doesn't take command lines, period.  So you are pretty much out of luck for that one.
For the record mamewah launches games exactly the same way as dk and laz do, using my wrappers and all.  So you aren't going to get any more compatibility by switching.
I encourage you to try mamewah anyway though as you seem to constantly have problems with my fes.  ;)
Demon-Seed
« Reply #3 on: July 28, 2003, 06:33:33 pm »
Hi,
I have it running pretty good now. Just every once in awhile I get error msgs. I will write them down and post them and maybe you might know the cause? I would like to try mamewah but I finally have grasped the concept of your front end. I believe that the errors are being caused by the mp3 playlist? all I did was make a playlist and called it background.m3u. what i find is, it will play one song then stop. or I get a path 76 error or something like that. I will write it down. I like DK its good. Just wondered the differences in the 2 front ends. I appreciate the feedback. thanks.
Demon-Seed
« Reply #4 on: July 28, 2003, 06:52:28 pm »
Ok I just got it. Run Time error 76 path not found. thats the one I seem to get alot.
Demon-Seed
« Reply #5 on: July 28, 2003, 07:10:49 pm »
and I looked into KI I still can not get it to work. There is a file missing in the wrapper?
u64emu.cfg -placed into cfg folder of dk and set up.
u64emu.dat -placed in dat location
u64emucatver.ini - placed in catver file
set up my dirs to D:\U64Emu\
run the list and it doesn't show up?
I did notice no file .ini to edit to point to the emu is that correct? sorry i am dumb anyone hlp?
Demon-Seed
« Reply #6 on: July 28, 2003, 07:59:44 pm »
ok great KI works got it!! sorry to bother you with the sensless posts i just had to play with it a bit
)p(
  • Last login:March 27, 2009, 03:38:15 am
  • We are the Galaxians...
    • Emulaxian:cabinet and frontend
« Reply #7 on: July 29, 2003, 01:42:58 am »
The main difference between dk and mamewah is hte graphics engine. dk uses directx which results in dk supporting lots of layering and transparency effects. So for the graphically inclined people like me dk is the first choice... All this fancy graphics stuff does take up rersources so for a low end system I would go for mamewah....
peter
Demon-Seed
« Reply #8 on: July 29, 2003, 10:14:22 pm »
right on thanks very much!
