Author Topic: how do you add a new console to Maximus Arcade?  (Read 10770 times)
animatorJustin
  • Last login:January 14, 2023, 11:09:32 pm
« on: March 22, 2010, 01:22:02 am »
i would like to add another console to the list but don't know how.
shateredsoul
  • Last login:January 25, 2013, 08:23:51 pm
Re: how do you add a new console to Maximus Arcade?
« Reply #1 on: March 23, 2010, 11:24:22 am »
which? I was able to add gamecube, naomi, and wii (all are not officially supported in Maximus Arcade)
The basics of what I did
1. I was able to get the system to run outside of Maximus (I did this before even trying to integrate the new emulator)
2. Try adding the exe and roms to another emulator you don't want to use, if it doesn't work with a another system (i.e. when i tried to use kawaks to install naomi it gave me issues, then I used visual pinball and it worked great!)
3. If this doesn't work you may have to figure out the command line, for Dolphin (the gamecube and wii emulator) I put
/e %file
in the command line, different systems may have different requirements.
4. Now you have to change the art.  If you installed a new system under dosbox you have to go into the theme editor and edit the dosbox theme to match the system you installed. In theme editor... Click on an image, then go to file, import and pick an image to import.  It will replace the image you clicked on. You will have to replace 3 things, the system image, the system name, and the system marquee.  also with some systems you will have to change the preview image.
good luck!
animatorJustin
« Reply #2 on: March 23, 2010, 07:19:19 pm »
I wanna add another virtual pinball, vp 9, i already have vp8 on there
shateredsoul
« Reply #3 on: March 23, 2010, 07:21:27 pm »
try setting up via the dosbox config menu
if virtual pinball has anything in the commandline copy it into the dosbox command line
and change the dosxbox art to represent virtual pinball 9
Just remember that from now on, when you see dosbox, it will represent virtual pinball 9
animatorJustin
« Reply #4 on: March 24, 2010, 10:43:48 am »
nope didn't seem to work, i opens vp 9 but does not open the rom  :banghead:
shateredsoul
« Reply #5 on: March 24, 2010, 12:30:01 pm »
try changing it to long path.. try installing it under another emulator.  Just mess around with it. Did you copy over the command line from vp8?
It also may be that vp9 needs different command line ... commands.  You can check their website and see if that's the case, if not just try installing it under another system.
Also, did you change the type of roms it scans for? so it can find your vp9 tables.
shateredsoul
« Reply #6 on: March 29, 2010, 03:04:31 am »
I don't have a cab yet, but I can show you how it looks on my pc within maximus.  I'll do it next weekend.
shateredsoul
« Reply #7 on: March 29, 2010, 08:03:00 pm »
I also just posted a quick guide on how to do this.. hope that helps
http://forum.arcadecontrols.com/index.php?topic=101463.0
