Author Topic: Monitor or isolation transformer problem  (Read 1512 times)
Cisek
  • Last login:May 19, 2023, 07:35:14 am
« on: March 17, 2010, 12:14:53 pm »
Hi
I've got fully working Wells Gardner K7000 in Mortal Kombat II cabinet. Everything was fine, until yesterday. When I turn the machine on, there is sound like a high voltage connected with monitor interferences and marque light blinking. It last for a second or two. I don't know if it is monitor fault, or maybe I've got problem with isolation transformer (if so, than what part should I replace?)
EDIT:
Now the whole machine doesn't even turn on. What could go wrong with isolation transformer?
« Last Edit: March 17, 2010, 12:37:08 pm by Cisek »
Ken Layton
  • Guru
  • Technician
Re: Monitor or isolation transformer problem
« Reply #1 on: March 17, 2010, 12:45:44 pm »
Isolation transformer powers only the monitor. If other things are not coming on then the monitor and isolation transformer are ok and to look elsewhere.
lilshawn
  • Last login:Today at 03:19:11 pm
« Reply #2 on: March 17, 2010, 01:12:27 pm »
often in the power supply it has a connector that powers the marquee and other whatnots (it's a green/black/white connector) it just passes the power on through when the power is applied.
chances are the power supply has cooked, test it with a voltmeter just to be sure.
Cisek
« Reply #3 on: March 20, 2010, 08:58:26 pm »
It turned out that power supply is fine, but the powerstrip got cooked, thanks for advices  :)
