Author Topic: Smallest arcade buttons?  (Read 5106 times)
LeedsFan
« on: August 06, 2009, 01:40:39 pm »
What are the smallest arcade quality buttons generally available? I'm looking for some buttons that take up less CP space than standard Happs etc. as I'm building a bartop. The smallest I've found are the Sanwa OBSF 24. Is this it? Of course they must be arcade quality.... I'm not just gonna install any old buttons just because they fit.  ;)
garnerb350
    • Hyperspin
Re: Smallest arcade buttons?
« Reply #1 on: August 06, 2009, 04:17:45 pm »
What about the old atari volcano buttons?
Ginsu Victim
  • Comanche, OK -- USA
« Reply #2 on: August 06, 2009, 04:43:05 pm »
Those aren't good for general gameplay. That's why I didn't recommend the Sanwa 18s or 20s. I think the 24 is about as good as you're going to get and still maintain arcade feel.
TOK
  • The Game Always Wins
« Reply #3 on: August 06, 2009, 05:42:39 pm »
I bought a couple of these for admin buttons. They have a great feel and they are certainly small (maybe too small for your use) but there are a couple of issues.
They're only about an inch long, so if you're going to use 3/4" or larger for the panel its gonna require some extra routing. The second thing is that I think they're only available in black.
Oh, there might be an issue since you're not in the US. Not sure though.
Bender
« Reply #4 on: August 06, 2009, 06:14:03 pm »
what he said
EwJ
  • Last login:October 12, 2022, 10:16:06 pm
« Reply #5 on: August 06, 2009, 06:34:00 pm »
Source?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
« Reply #6 on: August 06, 2009, 09:14:54 pm »
Loads of us build bar-tops with no problems; just how small are you planning on going? A regular 1-player, 6-button arrangement only takes up around 9" x 4" after all.
LeedsFan
« Reply #7 on: August 07, 2009, 12:40:12 am »
I'm building a replica Donkey Kong half size bartop (it's in the projects section). The CP measures 294 x 103 mm. With the scaled down DK artwork I really do struggle to get any kind of arcade buttons in there.
I'm thinking of using non-arcade buttons for P1 and P2 as they aren't "play" buttons. Something like what TOK posted may be ideal (even though they are black). Then I can just get a Sanwa OBSF-24 in there for the Jump button. Having said that the "Jump" decal within the artwork will need to be enlarged to accommodate the 27mm radius button.... but it will just fit. I was gonna fit an extra "action" button on there for two button games like Scramble, 1943 etc.etc. but I may need to knock that idea on the head now that I see what area I'm restricted to.
TOK
« Reply #8 on: August 07, 2009, 05:28:20 am »
LeedsFan
« Reply #9 on: August 07, 2009, 05:41:12 am »
Source?
I'm almost embarrassed to post it.  ;D
http://www.radioshack.com/product/index.jsp?productId=2062508
Out of interest what is the outside diameter of the button casing/bezel on top of the CP? The specs say it mounts in 0.5" hole but doesn't say the size above panel.
garnerb350
    • Hyperspin
« Reply #10 on: August 07, 2009, 09:13:23 am »
what he said
Sorry guys...i was loopy from pain meds yesterday...I only remember "small" & arcade buttons"...
 :banghead:
I thought the OP was going in the admin button direction...
retrofuture
  • Last login:August 24, 2022, 12:41:44 pm
    • RetroFuture
« Reply #11 on: August 07, 2009, 09:38:56 am »
Gremlin Solutions supply them in the UK http://gremlinsolutions.co.uk/ordersanwapushbuttons.php , I've bought some yellow ones from them in the past.
The Sanwa Buttons OBS-24B may be easier to install in wood though they'll still require some routing or drilling.
The future isn't what it used to be.
Xevious BartopRetroFuture
