Author Topic: volume knob for pc  (Read 3423 times)
deoblo85
  • Last login:April 01, 2025, 01:22:30 pm
  • GAME or DIE
volume knob for pc
« on: January 20, 2009, 11:07:54 am »
Does anyone know were i can get a volume controller usb for my jukebox (pc) that lights up and not a grffin powermate knob? :banghead:
whammoed
  • Last login:April 17, 2026, 12:27:07 pm
  • Crack don't smoke itself
    • NiceMite
Re: volume knob for pc
« Reply #1 on: January 20, 2009, 11:38:09 am »
u-hid from ultimarc now supports mechanical encoder input translated to button presses or keyboard strokes.  You would have to design your own lighting and listen for the button presses to change the volume with software.
Don't know of a good ready made solution besides the powermate which has that issue of not being recognized.
I started to put together a little app to recognize the presses and change system volume...I should finish it up.
whammoed
    • NiceMite
« Reply #2 on: January 20, 2009, 11:53:02 am »
Forgot about this product:
http://www.digitalconnection.com/products/remote/imon_knob.asp
Not as nice looking as the powermate imho, but if it works better...
deoblo85
  • GAME or DIE
« Reply #3 on: January 20, 2009, 01:03:31 pm »
Perfect thats just what i was looking for thanks!!!
ahofle
    • Arcade Ambience Project
« Reply #4 on: January 20, 2009, 03:10:33 pm »
Wasn't sure if you knew, but CabVol will actually adjust the volume via key presses (or mouse movement):
http://forum.arcadecontrols.com/index.php?topic=69901.0
Visitor Q
  • Last login:May 01, 2019, 09:09:30 am
  • The Saw Is Family
« Reply #5 on: January 20, 2009, 03:28:24 pm »
Anyway to get some Vista 64 support?
On another note, can you use a Media Center remote to control volume in windows with out MC loaded?
« Last Edit: January 20, 2009, 03:33:38 pm by Visitor Q »
“Woe be unto him who opens one of the seven gateways to hell, because through that gateway evil will invade the world."
whammoed
    • NiceMite
« Reply #6 on: January 20, 2009, 03:40:51 pm »
I did look at that, but it wasn't quite what I needed.  Maybe it was because initially I was going to put it together for parallel port input?  I was planning of finishing it using gamepad button input...does it do that?  I don't recall.
stephenp1983
  • Last login:March 24, 2024, 11:26:39 am
« Reply #7 on: January 20, 2009, 06:56:28 pm »
I have a media center IR usb receiver, and I think it works in none media center versions of xp.  Not sure if the volume works though, as I've only used it with my harmony remote.  I'll try to dig it out and try.
ahofle
« Reply #8 on: January 20, 2009, 11:48:34 pm »
Ah, no joystick input support (yet).  :(
Ginsu Victim
  • Comanche, OK -- USA
« Reply #9 on: January 21, 2009, 12:08:27 am »
Those wanting joypad support can use xpadder or joy2key.
Visitor Q
  • The Saw Is Family
« Reply #10 on: January 21, 2009, 09:23:12 am »
All and all, xpadder is great!
